Can not disconnect MAF from stock air box...
got 2 of the bolts off fine with no problem, the other 2 spin on the other side, and i cant see to find a way to keep them from spinning ... cant fit a wrench in there, or a socket ... anyone have this problem when removing theirs? how did you do it?
got the maf off finally, and yes the honey comb got a little bit ****ed up
now, removing the intake pipe from where it connects to the turbo ... impossible. the clamp that holds it on, the bolt is not facing me when i look down at it through the engine, instead, where it needs to unscrew is under the car, in a 100% inaccessable spot. was anyone elses like that? because i am TRYING to figure out a way to remove the plastic tube from the turbo, and it really seems like it just 'can't be done' i can not figure out a way to access the bolt ... i dont even think i can get to it from the top of the engine with a long extension and a swivvlehead... =[ wth! who does this!
i dont think it will be able to work ... it seems like EVERYTHING is in the way, the unmovable parts of the car.... but... its worth a try. waiting on a friend to bring over his swivvleheads.
by the way, the head of the screw is not facing the ground, its sideways.... like
-----> like that, but from under the turbo.
You messed up your honeycomb? Ooops. The best way to get your maf off your air box is to use and air wrench. A real quick turn from the air tool will free them without f'in things up.
the honeycomb is not that bad... i bent a few fins, i might be able to fix them.. the thing that i am concerned with now is getting that pipe disconnected from the turbo. it is going to be a pain the way its on there. going to be very aggrivating i am sure, and lots of screaming
but hey! after thats off, ill have completed the rest of it in like 10 minutes!
damn mitsus!!
but hey! after thats off, ill have completed the rest of it in like 10 minutes! damn mitsus!!
