Help with factory cat orientation
Old Oct 20, 2006 | 10:34 AM
hotrod2448's Avatar
Which way does the factroy cat normally install?
Studs to the front of the car or rear?
Old Oct 20, 2006 | 12:03 PM
hotrod2448's Avatar
Ok. The factory DP has studs on it where it meets the cat right?
Old Oct 20, 2006 | 12:11 PM
RoadSpike's Avatar
I remember taking bolts off my cat when i installed a downpipe. Don't remember it having studs..
When i get home i'll look at my old downpipe if you haven't been helped.
Old Oct 20, 2006 | 12:34 PM
ElToro's Avatar
I remember there being studs on the cat to connect to the cat-back. Can't help you with the downpipe since I didn't separate the two when I installed my TBE.
Old Oct 20, 2006 | 12:37 PM
2vonku's Avatar
The side with the the two bolt are for the catback. The threaded side of the cat goes to the DP. Thats what I seeing on my Evo9. Hope this help.
Old Oct 20, 2006 | 12:46 PM
EvolvedDSM's Avatar
Due to the orientation of the flanges, it can only be installed correctly one way--studs mating w/ the IP and the bolts connecting it to the DP.
