problem with my throttle?
Old Oct 23, 2006 | 01:36 AM
nimanos's Avatar
hi guys
I am new here and have a 05 evo with down pipe, test pipe, and a greddy electronic boost controller.
recently i am having this problem with my gas pedal when i press about half a inch or so instead of cruising at same rpm all of a sudden my rpm goes up by 1000 and dropps again .do you guys have any idea where might the problem be?
thanks for your help it is driving me knots.
Old Oct 23, 2006 | 02:00 AM
DanJ's Avatar
maybe a slipping clutch? does this happen more often in the higher gears (6th,5th)?
Old Oct 23, 2006 | 02:23 AM
prench's Avatar
how is your idle? if that is choppy I would check for air leaks in the intercooler piping.
Old Oct 23, 2006 | 04:51 AM
Greg K's Avatar
what happens if you mash the throttle. my initial guess would be your clutch is slipping.
Old Oct 23, 2006 | 04:54 AM
3SgteGuru's Avatar
^+1 get on a highway an Floor it, does your RPM go up and not your speed?
Old Oct 23, 2006 | 07:07 AM
PcK EvO's Avatar
yup its prolly just a slipping clutch......mine started that a while ago and i bought a ACT.....just fix it now, it will only get worse.
Old Oct 23, 2006 | 07:12 AM
glgz's Avatar
Ditto on the slipping clutch theroy
