Does remote start work with immobilizer?
Old Oct 29, 2006 | 08:34 AM
tony_b's Avatar
I just bought a remote starter and I just realized I had an immobilizer. duh.
Is this going to pose and issue? Is there a workaround I'm going to have to do when I install?
Old Oct 29, 2006 | 08:37 AM
SlowCar's Avatar
i seen it work on 2 evos
Old Oct 29, 2006 | 08:43 AM
bigric09's Avatar
you have to buy a box that stores your key locally to read the code to start the car, you are also going to have to bypass the clutch pedal sensor
Old Oct 29, 2006 | 09:00 AM
diablo2184's Avatar
what box? whats it called? where can you get it?
Old Oct 29, 2006 | 12:55 PM
tony_b's Avatar
about the box, do you mean you have to keep a spare key somewhere next to the ignition somewhere or is it a box that replicates the signal from the chip in the key?
Old Oct 29, 2006 | 07:02 PM
03redtype-s's Avatar
Tony
check your pms bro i explained it to you!!!
Old Oct 30, 2006 | 05:26 AM
rsboy's Avatar
I'ts an immobilizer bypass box. Check ebay for some of those..
Basically it connects to the autostart/alarm and you put your spare key in it so you can bypass that feature and be able to autostart your car.
I'd suggest buying an extra key, have it reprogram for your evo and then grind the teeth down so no one can use it, just in case.
Old Oct 30, 2006 | 05:38 AM
kmcconn9's Avatar
/\ well said..
The only thing is that the immobilizer box is an interface and does not by any means bypass the immobilizer. All the box does is send the signal upson remote starting your vehicle to the key cylinder via a series of copper wire strands that are looped around your key cylinder and thus providing the ecu with the correct code to start the car..
DEI makes a great piece and is reasonably priced...DEI 556UW is the model number..any of your local circuit city stores will have this item in stock...
Old Oct 30, 2006 | 09:56 PM
SophieSleeps's Avatar
search for 556UW by directechs
I just bought a remote start. Am doing the install within the next few days.
Tony, where are you located? I'm in Lexington.
