Radio and Dome Light Dont Work! HELP!!!
Old Oct 29, 2006 | 11:09 PM
evo ippo's Avatar
Never mind
got it to work
Old Oct 29, 2006 | 11:12 PM
coolguycooz's Avatar
what do you mean you cant get to it. Pop out the dimmer switch holder. Get a pair of needle nose, and gently pull em out. Also check the ground, i dont know if they all share the same ground?
Old Oct 29, 2006 | 11:41 PM
evo ippo's Avatar
i wasnt talking about the in cabnin fuse box all the fuses in there are fine i am talking about the fuses in the engine bay. the is a pair of fuses (dome light and radio) that they have like a yellow holder qround it that refrains me from getting the fuse out and checking it . any advice???
Old Nov 5, 2006 | 08:14 AM
Boston'sEvO-->8's Avatar
Bump on this I will attempt to pull them out with a needle nose plier but what about the ground?? My radio and dome lights dont work and if the key is not in the ignition nothing works locks...headlights...etc...is this because they run off the radio and dome lights? If not could it be the ground? Where is that...thanks=)
