Best Downpipe and high flow cat?
Old Nov 1, 2006 | 12:35 PM
Jamie@WORKS's Avatar
Originally Posted by morgo333
works works works.....ummm ya.
As far as the check engine light, if the cat is functioning as intended to reduce emissions output, the light should remain off.
Old Nov 9, 2006 | 09:18 AM
Evo9Kid's Avatar
i had an hks but didnt like ti because it was 2.5" so i went with extreme technologies downpipe and test pipe and got great results... but i here for downpipe dc sports is the best...
Old Nov 9, 2006 | 03:19 PM
AutoXer's Avatar
Originally Posted by Jrod@Buschur
The dent would need to be right on the one bend around the diff. The clearance on the older style is not enough to clear the active diff. Its not a BIG dent but it will be a dent.
The "flex" on the stock downpipe is from the spring bolts. We have used our downpipe forever without a flex section and its been problem free and have had no issues with that. We can install a flex in the downpipe for an additional $90. Its up to the customer if they want one.
Jarrod
Buschur Racing Inc.
I wouldn't recommend getting a DP from Buschur with the flex section. The one they sold me hit my differential housing. I kinda expected a "send it back to us and we'll fix it" response to the problem, but it still hasn't been fixed. I had to trim a heat sink fin on my diff housing to get it to fit at all. It's still too close and is likely causing me false knock. See the following thread for pictures:
https://www.evolutionm.net/forums/sh...d.php?t=233495
Old Nov 9, 2006 | 03:21 PM
VenomEVO8's Avatar
Originally Posted by mdacko
i'd recommend buschur dp & high flow cat.
I second this recommendation
kayouu
Feb 29, 2016 06:58 PM
MisterRegato
May 9, 2015 07:39 AM
Carloverx
Northeast Region
Jan 9, 2008 05:30 PM
04 rs
47
Dec 17, 2005 06:28 AM
inariv5573
37
Mar 31, 2005 08:04 PM
