my fuel door will not open
Old Nov 6, 2006 | 11:11 AM
evo8rcr's Avatar
Unhappy my fuel door will not open
some damn plastic clip feel out when I closed the door and when I tried to open again it wouldn't I called mitsu and they said it would be covered under warranty but what a pain in the *** should I take my exhaust off when I go in to avoid my warranty being canceled? thanks
Old Nov 6, 2006 | 11:29 AM
Dont Try To Run's Avatar
Depending on your dealership, I would suggest taking your exhaust up. Have you been there before with it on?
TJ
Old Nov 6, 2006 | 11:30 AM
monies41's Avatar
you shouldnt have a problem unless they have a problem with you.
Old Nov 6, 2006 | 11:50 AM
otter's Avatar
EvoM Administrator
It's just an exhaust, you should be fine.
Old Nov 6, 2006 | 11:55 AM
~EVILEVO~'s Avatar
just buy a new peice and slide it on, were the old one broke off.... it only cost like $5
to open your gar door prop the lever on the drivers side floor up, then walk around and pull the door open.
goodluck
Old Nov 6, 2006 | 12:33 PM
evo8rcr's Avatar
goodluck
I was thinking the same thing but I wasn't able to get it pop it open I didn't want to scratch the paint I'll probabky try it later
Old Nov 6, 2006 | 01:29 PM
gsrboi80's Avatar
Pull the pop button get a piece of hard rubber or plastic (So not to scratch the paint) Pry the door open and get the new piece from Mitsu
