p0171 helpppp
Old Nov 7, 2006 | 06:55 PM
krazy srt4's Avatar
p0171 helpppp
today i pulled engine code p0171 which is system lean and all i have is a catback and hks bov (evo nine mr) any one noe any info on this??
Old Nov 7, 2006 | 06:56 PM
WrX Kila's Avatar
Try to route the bov into the itake if you had not done so aleady.
Old Nov 7, 2006 | 06:59 PM
krazy srt4's Avatar
yeah i gotta get the recurculation kit... if not is there any way to bypass that problem cuz i want the bov to be loud and not quiet
Old Nov 7, 2006 | 07:15 PM
Cirrusly Evolvd's Avatar
I too have the same code and it never stays gone for long. I'm recircing with a Greddy RS. Check you fuel cap, vacuum hoses and CRC canister (it's under the left rear between the bumper and wheel) Make sure all those hoses are connected.
Old Nov 7, 2006 | 07:16 PM
krazy srt4's Avatar
can it hurt the car alot or just a simple read off the comp???
Old Nov 7, 2006 | 07:20 PM
KUEvo's Avatar
Why don't you put the stock bypass valve back on? Who cares about the sound if it does nothing?
Old Nov 7, 2006 | 07:24 PM
krazy srt4's Avatar
it does nothin but it sounds nice
Calling him out because of his choice of BOV does not help the situation.
Did you get the CEL after you installed the BOV or is this something that just came up out of the blue? A bad tank of gas can cause this code also...
Iceplant18's Avatar
That engine code i've found is often associated with a vacuum leak somewhere around the manifold. Like said before, check all your vacuum lines to see if there's anything abnormal.
Old Nov 7, 2006 | 07:36 PM
KUEvo's Avatar
I did not call him out. I merely presented a plausible answer to his question and then offered my opinion. I apologize if I hurt your feelings.
Old Nov 7, 2006 | 07:42 PM
How did you present a plausible answer without verifying the facts? You then stated a subjective opinion by saying "who cares about sound..." Perhaps he does, who are you to judge?
You didn't hurt my feelings, but you sure didn't help him at all by your statement.
krazy srt4's Avatar
the cel came out after a while
Old Nov 7, 2006 | 07:44 PM
Then I doubt the HKS is the cause. Check for any loose or disconnected vacuum hoses, make sure your gas cap is on tight and clear the code. Fill up your gas with a different brand and see what happens.
Old Nov 7, 2006 | 07:57 PM
KUEvo's Avatar
You're right. I will succumb and go put a bunch of stickers on my car.
Old Nov 7, 2006 | 08:07 PM
krazy srt4's Avatar
yeah i'ma give it a try ... thanks alot for the help
