Megan Gasket ?
Old Nov 9, 2006 | 10:39 AM
Redline-Z's Avatar
Veteran: Air Force
Megan Gasket ?
I am about to instal my Megan manifold and Megan 02. My question is should I use the supplied gaskets or should I purchase OEM gaskets? Anyone use the supplied gaskets, if so how did they work?
Old Nov 9, 2006 | 11:07 AM
Ducu's Avatar
oem one... half of my megan gasket went off 3 days after i installed it!!!
i had to adjust it to my turbo as well to fit perfectly... but u should do that after you drive with it for a couple of weeks becouse after high temp it bends a little!
Old Nov 9, 2006 | 05:37 PM
kekek's Avatar
I would use the OEM gasket at the cyl head connection and the Megan gasket at the turbo hotside connection. This was necessary for me since the manifold's mating surface was not totally flat and leaked with an OEM gasket, the extra "squish" in the Megan one helped to seal it up.
Old Nov 10, 2006 | 07:11 AM
Zeus's Avatar
OE gaskets for anything ahead of the downpipe...
Old Dec 13, 2006 | 12:05 AM
diablo2184's Avatar
does the OEM donut gasket fit a 3.0" o2 housing to downpipe?
Old Dec 13, 2006 | 02:42 AM
fimotorsports's Avatar
use the factory gaskets
Old Dec 13, 2006 | 06:31 AM
diablo2184's Avatar
for the Invidia 3 inch O2 Housing, when the stock O2 is smaller?
Old Dec 13, 2006 | 07:12 AM
ries's Avatar
+1 on using the OEM gaskets for O2 housing, hotside, mani.....
the ones supplied w/ the megan housing and mani are crap and will burn up and cause an exhaust leak
Old Dec 13, 2006 | 07:58 AM
Ramen_Noodle's Avatar
+2 on using OEM gaskets. I have the Megan manifold installed in my car, the supplied gasket that came with it didn't last 2 weeks. When I bought the car I immediately replaced the gasket with an OEM turbo housing gasket and everything has been great since.
Old Dec 13, 2006 | 08:02 AM
LI Pinky's Avatar
Yesssir, def. use the OEM gasket, i helped install a Megan manifold on an evo 9 and not 2 days into driving it the gsket actually blewout, OEM is def gonna be the way to go, thicker and more reliable...
Old Dec 13, 2006 | 10:43 AM
yes, the factory gasket between the turbo and 02 is open and only covers the outer edge. You should be able to re-use it unless you mangle it. The 3 inch 02 housing refers to the bottom portion where it mates to the downpipe... now I believe invidia my provide that donut gasket.
Old Dec 13, 2006 | 10:49 AM
Ultimate CC's Avatar
oem is the only way to go..
Old Dec 13, 2006 | 03:15 PM
Redline-Z's Avatar
Veteran: Air Force
Thanks guys OEM it is.
bboypuertoroc
Apr 25, 2011 07:29 AM
kozmic27
Jun 28, 2009 11:38 PM
W_evo8
10
Jan 25, 2008 03:23 AM
RevMoto
Sep 4, 2007 08:33 AM
BUCKNAKED
Nov 16, 2005 03:03 PM
