tail light problem
Old Nov 27, 2006 | 05:36 PM
sp00lin2g's Avatar
tail light problem
ok so i noticed tonight that my reverese lights don't work. My lights, brake lights, and turn signals all work fine. I checked the bulbs they are fine i also checked the fuses and relays up front and they are fine. Anyone ever have this problem before or have any insight on what my be the cause.
thanks
chris
Old Nov 27, 2006 | 07:21 PM
barneyb's Avatar
Well, it is the simplest circuit on the car. The wire goes from the ignition switch to fuse #3, then to the backup switch on the tranny, to the backup lights and then to ground. So check the fuse and then check for continuity at the backup light switch on the tranny when in reverse and that there is power down to the switch. If that is all good then it has to be the wire going to the rear.
