Any Fake Cats out there?
Old Nov 28, 2006 | 05:41 AM
High_PSI's Avatar
Due to my town and surrounding areas being well known for street racing, the local authorities have taken it upon themselves to pull over cars that look modified and do a spot check which is basically looking for cats, improper lowering, yadda yadda yadda. My car is 100% stock at the moment but I would like to modify it eventually with a turbo back. I would like to make a "Fake Cat" to pass the visual which would basically make me much safer to the fines, towing, etc.
Anybody have any pics or the best way to go about this? Thanks
Old Nov 28, 2006 | 05:47 AM
Roldy's Avatar
Here you go:
https://www.evolutionm.net/forums/sh...d.php?t=208908
Old Nov 28, 2006 | 05:50 AM
jmoudry's Avatar
Originally Posted by Roldy
Tou beat me to it.
You could also gut you current cat by smashing out the catalyst.
Old Nov 28, 2006 | 05:53 AM
MalibuJack's Avatar
Not that I know of.. You can make your own..
Though I have heard Buschur carries a "Jack Russel" in stock...
Old Nov 28, 2006 | 08:38 AM
RogueSTi's Avatar
I used a large screwdriver and a medium sized prybar to knock out (or gut) the OE cat. on my old civic ...would work in this application too. cost $0. Time 1 Hr.
Edit: this would probably flow better...
Old Nov 28, 2006 | 08:44 AM
MalibuJack's Avatar
Originally Posted by Evillusion
I used a large screwdriver and a medium sized prybar to knock out (or gut) the OE cat. on my old civic...would work in this application too. cost $0. Time 1 Hr.
I definitely would stay away from the knocking out thing.. Although it removes the guts of the cat, it may inherantly make things worse.
It makes more sense to keep the catalytic converter or get a larger aftermarket unit.. I really don't understand the obscession with the 5-7 hp difference between an aftermarket cat and a straight pipe..
Old Nov 28, 2006 | 08:47 AM
ROGERV's Avatar
RRE makes one. you have to call them they don't have it on their web site
Old Nov 28, 2006 | 08:50 AM
Ralph's Avatar
I really want to do this but don't want to hack up my perfectly good cat. I'll need it for SMOG.. and in CALI even if you have a cat, they may still send you to a smog referee... damn -_-.
Wonder if any sites sell cat SHELL's... hmm .
Old Nov 28, 2006 | 08:51 AM
*sam*'s Avatar
+1
RRE "Rally Cat" ftw
Old Nov 28, 2006 | 10:52 AM
High_PSI's Avatar
It's actually about 15WHP, it also holds off the detonation threshold, it allows faster spoolup, it adds torque, technically it should aid in gas mileage as you are removing a restriction.
It is noticeable whp across the board, I have removed three cats from three separate cars, all aided in WHP noticeably.
Old Nov 28, 2006 | 11:02 AM
Smike's Avatar
Someone say fake cat!?!
http://www.wildlifetreasures.com/sleepkittiesorder.htm
Gotta love Google....and we live in a wierd world...
Rodly has it - test pipe with the heat shield from the org. cat.
Old Nov 28, 2006 | 11:09 AM
MuslimEvoFreak's Avatar
^ WTF?! lol
Old Nov 28, 2006 | 11:45 AM
Jax419's Avatar
haha! I guess you can talk to SmikeEvo for one! are you in cali?
Old Nov 28, 2006 | 12:22 PM
oldscholevo's Avatar
tell me about it!!!
Old Nov 28, 2006 | 12:48 PM
Smike's Avatar
Ya that was to be one of the wierdest things I have ever seen. I dare not ask why someone would want a stuffed fake cat...
Ok, back on topic.
If you live in an inspection only state - then the cat-cover trick should work. But if you live in a smog state (cali, nj...) Make the cat-cover test pipe, but keep yours for inspection time.
j-motive
Apr 26, 2010 09:49 PM
ch53avitech
Mar 25, 2009 05:12 PM
lawdogg
Northeast Region
Sep 30, 2005 05:01 PM
d2sEvo
Oct 21, 2004 04:45 PM
Barse
Lancer Engine Tech
29
Jun 11, 2002 07:59 PM
