thoughts on 37R..
Old Nov 28, 2006 | 06:53 PM
WhtEvo05's Avatar
Originally Posted by GT35REVO8
true..well on a stock block and 35R with 27psi and the mods i listed AMS said i can crack 500awhp on pump...so maybe ill just stick with 35R
I think AMS gave you good advice.
Good luck
Old Nov 28, 2006 | 09:43 PM
Jean's Avatar
well can i run a 37R on stock block?
with aem 5bar uego/wideband/1000cc inj/fuel pump/ams fuel rail/ams fpr/buschur intake mani ported/buschur race core with piping/alky/fulll 3in exhaust/ngk bpr8es plugs/throttle body/272 cams
with that set up can i run 37R or just stick to 35R?
Yes you can run it on a stock block if you choose to. with the supporting mods you will be fine.
Lag really isnt that bad.
Plus that turbo will still have room to make more power if you run C16 and or build you motor eventually.
