so im testing riiight now...
Old Dec 3, 2006 | 12:20 PM
ddubdb3's Avatar
so im doin a boost leak test right now....i have the homemade tester radiator hose clamps pvc cap and tire valve. when i use my tire inflator the built it psi gauge goes nowhere it sits at zero. i took it off and checked with a tire pressure gauge..nothing. do i just have to let the inflator sit there for like ten minutes or what?? when i press the tire valve air does come out...
Old Dec 3, 2006 | 12:24 PM
ddubdb3's Avatar
o looked at the boost gauge but it seems to rise and then wont go past .5 bars....
Old Dec 3, 2006 | 12:35 PM
Warrtalon's Avatar
Not getting enough pressure, or it's all leaking out somewhere.
Old Dec 3, 2006 | 12:39 PM
ddubdb3's Avatar
yea while it sits at .5 theres a super faint whizz coming from the turbo some where any ideas on what it could be...
Old Dec 3, 2006 | 12:43 PM
Warrtalon's Avatar
Yeah, you don't have a good seal or have a huge leak. Find where the noise is coming from.
Old Dec 3, 2006 | 12:44 PM
ddubdb3's Avatar
yea my car wont hit full boost anymore. its stock and usually at wot it sits at 1 bar instead of 1.3....
Old Dec 3, 2006 | 12:46 PM
Warrtalon's Avatar
Ok, well you obviously have an issue, but it's not necessarily a boost leak. Find the hiss and eliminate it. Also, tell us in exact detail the symptoms you're experiencing - rpm, gear, boost, noises, everything.
Old Dec 3, 2006 | 12:48 PM
evrblazin's Avatar
If it's stock why spend all day f-in with it? just take it to the dealer. Unless you are trying to learn something. That's a different story.
Old Dec 3, 2006 | 12:53 PM
ddubdb3's Avatar
well yea this is my first turbo awd and manual car...i wanna learn more about it. if i cant figure it out i can always just take it to the dealer. i had a bov i know it shouldn't have been my first buy but i think it had it adjusted too tight which led me to this problem
Old Dec 3, 2006 | 12:56 PM
evrblazin's Avatar
which BOV do you have?
Old Dec 3, 2006 | 12:57 PM
ddubdb3's Avatar
i had the greddy rs but i put the stocker back on.... so the hissing noise is way to faint to pin point and while the compressor is off the boost gauge drops suuuuper slow.
Old Dec 3, 2006 | 12:59 PM
dxbtune's Avatar
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
Out of interest:
Which BOV? and is it VTA?
Old Dec 3, 2006 | 01:04 PM
Warrtalon's Avatar
Yes, purchasing an expensive bov when your IX BOV is better was dumb, but it didn't cause this problem. If you're doing a boost leak test, you should be using a squirt bottle with soapy water - that's how you find the hiss. How else did you plan to find leaks?
What do you mean "and while the compressor is off"? What does that mean?
ddubdb3's Avatar
vta makes the loud whisssshhhh noise and releases its air pressure to the atomsphere its a type of bov. i have the recirulation valve which routes the air that makes the loud whiiiisssssh back into the intake intead of into the atomsphere
Old Dec 3, 2006 | 01:06 PM
ddubdb3's Avatar
could the my wastegate be making the hissing noise???
