turbo timer help
Old Dec 21, 2006 | 11:01 AM
filter's Avatar
turbo timer help
ok now im totally confused i bought a hks turbo timer and harness.
but after reading it seems the harness is only for the power stuff but i still have to splice in for rpm and speed signal. wtf i thought this harness was so i didnt have to cut any ecu wiring.
can anyone help me with a wirirng diagram for the ecu since it seems im going to have to splice what a waste of money on this harness.
Old Dec 21, 2006 | 11:06 AM
FiftyFive's Avatar
The harness will allow you to use the turbo timer function. For rpm and speed signal you will have to splice wires.
Old Dec 21, 2006 | 11:07 AM
filter's Avatar
is the ecu layout the same for the 8 and 9 ecu or can you point me in the right direction for a layout of the 9 diagram. im still looking for a diagram.
puff n pass's Avatar
i have the hks one but didn't use a harness at all, don't think i can be much help to you
Old Dec 21, 2006 | 11:15 AM
FiftyFive's Avatar
http://www.roadraceengineering.com/e...-ecuwiring.htm
This is for the 8, as for the 9 im not sure what changed
Old Dec 21, 2006 | 11:47 AM
filter's Avatar
i foudn that but want to know if the 8 and 9 ecu are the same.
Old Dec 21, 2006 | 11:59 AM
filter's Avatar
now im totally confused i thought the harness installed of the ecu. where does this harness go?
Old Dec 21, 2006 | 12:07 PM
tarmac4g63's Avatar
the harness is for the ignition
Old Dec 21, 2006 | 01:11 PM
ToTheIXs's Avatar
if you tell me what color wires are for what signal i can tell yo what wires to tap in the ecu, i had that tt installed but i hated how it didnt match my interior...but those signal wires are still there, so i can just look at the ecu harness' and tell you which wire to splice
Old Dec 21, 2006 | 01:20 PM
filter's Avatar
theres brown and green i think one goes to rpm and the other to speed meter.
Old Dec 21, 2006 | 01:30 PM
TouringBubble's Avatar
IX ECU is different
Pinout here
Old Dec 21, 2006 | 01:52 PM
filter's Avatar
Originally Posted by TouringBubble
IX ECU is different
Pinout here
i @$@%@#$@3 love you man. now to see if i can get these other 2 wires hooke up.
ok is wire 80 what i want for speed sensor and which one for RPM i seem to be over looking at it or is it called something else?
Old Dec 21, 2006 | 05:32 PM
45 is tach, 80 is speed. Good luck with the install. I'm installing one soon as well =). the pinout was correct for my shift light install, so I'd rely on it.
Old Dec 21, 2006 | 06:13 PM
evo_tiago's Avatar
hope this helps you. click home,then evo tech, installation,electronics. http://evomoto.com/index_tech.php?tP...5e92818fe64180 ime gonna do it tomorrow.good luck bro.
Old Dec 21, 2006 | 07:24 PM
filter's Avatar
nice write up but its for an 8 not a 9 as far as the ecu
