problem installing JDM MR Headlamps
Old Dec 25, 2006 | 09:31 AM
donmeca2020's Avatar
well everything has went ok until i started changing the bulbs and one of the connecters on each side of the us lamps did not fit on the jdm ones. when i was about to connect them i noticed none of the bottom connecters match. i am aware that their is a wiring harness you could buy but i thought that was for fog lights. and i know the headlight bulbs have to be changed to D2 bulbs anyways any info on my install to help me get these badboys in would be great! mind everyone i did search nothing came up. anyways MERRY CHRISTMAS GUYS!!!!
Old Dec 25, 2006 | 09:41 AM
evo637's Avatar
you have to slice and replace the usdm foglight harness to a jdm one. Sorry I forget which kind, but I do remember I swap mine out with nokia bulbs. The only bulb I needed to change was the foglight..
Old Dec 25, 2006 | 09:45 AM
well thing being is i have a non SSL evo, i was planing on doing installing some fogs later on but right now im trying to figure out what the hell to do
Old Dec 25, 2006 | 09:52 AM
Evo05lution's Avatar
you will need this...http://www.lancershop.com/customer/p...&cat=66&page=2
Old Dec 25, 2006 | 10:34 AM
I-Dom-In-8's Avatar
Hes not talking about the FOGS....hes talking about the Low beams..Sorry i cant help ya out man.Btw the Fogs are 9006...I know because i have a set of the headlights waiting to go on myself.
Old Dec 25, 2006 | 10:58 AM
Sxhawnn's Avatar
reason why it doesn't match is because the jdm headlights are meant for HID applications. If you have a non-ssl evo.... then you either need to source the Hid assembly from some other evo or take it to a light shop and have them recommend you an hid kit that would mate to the headlights.
Old Dec 25, 2006 | 11:26 AM
Boltz.'s Avatar
FCOTM Winner
You have 9006 low beams on your evo stock and the headlights call for D2S bulbs.
Don't even bother trying to fit in the 9006's into the Mr's, its not worth your time.
You need an HID upgrade which adapts from a 9006 harness to a D2S bulbs which most HID places will sell..
PM me for more questions as I will most likely not check this thread again.
Old Dec 25, 2006 | 11:39 AM
oh crap i miss read the thread...
yes basically you are screwed f you have a NON HID evo...
Old Dec 25, 2006 | 05:11 PM
rogue's Avatar
Sell me your MR headlights or buy my HID package (one of us should benefit):
https://www.evolutionm.net/forums/sh...85#post3791385
Old Dec 25, 2006 | 09:58 PM
yea right...... as for the D2 bulbs, i will get some tomorrow from my HID hookup, my friend also showed me an easy way hook up the stock usdm harness to the JDM light only splicing a corner light. so all in all should be an easy hook up.
Old Dec 26, 2006 | 07:02 AM
rogue's Avatar
ok... good luck with your wire splace hookup...lol.
Old May 30, 2009 | 05:30 PM
MR. stEVO's Avatar
can u tell me how to do this please??
Old May 31, 2009 | 01:45 PM
hiphopislife's Avatar
you're better off going with an aftermarket HID kit, which is what I did to use the jdm lights
Old Oct 12, 2009 | 06:37 PM
kyoo's Avatar
I think Gruppe-S sells non HID JDM headlights
Old Nov 28, 2009 | 07:52 AM
Saleentones's Avatar
Just bought the harness for fog lights from Lancershop.... Any one know what bulbs will I need to purchase now? Thanks!
