Let the modding begin!!!
Old Jan 10, 2007 | 01:55 PM
ultimatesteve's Avatar
Originally Posted by jmartinez1170
Anything outside of hks 280's is to much for stock turbo. The performance is the same as the 272's but a lil more top end. On a stock turbo you should see a good 10-25 whp depending on tune.
15-25hp.... Thats it? I was under the impression you should see 25-35 even on a 03-04?
Old Jan 10, 2007 | 02:13 PM
LVIIIR's Avatar
Originally Posted by bullfrg
Aren't the 2005 turbos the same as the 9 turbos? Now if you had an 03 like me then the 9 turbo makes sense, which is why I am running one.
No the turbo's on the 9's have a bigger compressor housing, than the 05's the difference between the 03-04's and the 05's has the larger 10.5 hotside which the 9 does as well
Old Jan 10, 2007 | 04:09 PM
evilevo22's Avatar
so whats improved on a 9 swapped on an 05 8 is it worth the money
Old Jan 10, 2007 | 04:13 PM
vito1's Avatar
Originally Posted by Extas
Should get a wideband.
+1.^^
Old Jan 10, 2007 | 04:14 PM
smokey's Avatar
I thought 280 cams on a stock turbo would be way too lopey at idle....and only used when doing a bigger turbo.....but I guess I could be wrong. I figured 264's or 272's would be best for the street and 280's would be good if you went to a larger turbo.
Oh well I guess you learn something new everyday
Old Jan 10, 2007 | 04:32 PM
evilevo22's Avatar
i heard the same thing are 280's on stock turbo ok or should i get 272's until i upgrade my turbo
Old Jan 10, 2007 | 05:50 PM
steevo's Avatar
You will like the 272's idle with your HKS Hi-Power, trust me
Old Jan 11, 2007 | 02:39 AM
evilevo22's Avatar
i cant wait for my exhaust to get here how does the hi power sound with a dp and test pipe
Old Jan 11, 2007 | 05:15 AM
Ultimate CC's Avatar
I would go with a jdm mr bov, 272 cams, evo9 turbo, licp, alky and a flash...
Old Jan 11, 2007 | 08:00 AM
jmartinez1170's Avatar
With the mods he has its not going to put out that much you need more supporting mods.
Old Jan 11, 2007 | 07:17 PM
evilevo22's Avatar
i also got ss o2 housing what improves with a new housing thanks
Old Jan 13, 2007 | 08:52 AM
Tim893's Avatar
i have a injen LICP for sell. let me know if ur interested.
Old Feb 28, 2007 | 12:19 AM
evilevo22's Avatar
well its been a while sense i posted this, but its updated now im ready for cams cant wait.
