High flow cat
Old Jan 13, 2007 | 10:48 AM
onesexyevo's Avatar
High flow cat
What up guys i just bought a full 3inch turbo back exhaust for my evo 8.
My question is should i also do a high flow cat too?
Old Jan 13, 2007 | 10:50 AM
Mitsu3's Avatar
most turbobacks come with a test pipe or a highflow cat. You could use the stock cat but it is not great for power. Get a highflow cat if you want more power and keep the noise down. If you want all the power you can get from an exhaust then get a test pipe but it will be louder. But yea i recommend you get a HFC.
Old Jan 13, 2007 | 10:52 AM
cij911's Avatar
Generally a TBE includes a HFC or TP. I run a Ultimate Racing Cat. and would HIGHLY recommend it as it will keep your car legal in CT., help the environment, and eliminate the emission stink of a catless setup...Yes you will loose ~5HP, but 99.9% of drivers would never know the difference....Yes it will make your car a bit more quiet...
Old Jan 13, 2007 | 11:00 AM
evo9guy's Avatar
Is it legal to replace the stock cat with a HFC in Ca.
Old Jan 13, 2007 | 11:08 AM
CRX2EVO's Avatar
no but they can't really tell the difference by looking at it
Old Jan 13, 2007 | 11:38 AM
evo9guy's Avatar
k thanks
Old Jan 13, 2007 | 02:01 PM
onesexyevo's Avatar
thanks for the replies guys!!!
Old Jan 14, 2007 | 03:17 PM
NoisyTurbo's Avatar
Get a random tech metallic cat and have ot welded into a off road pipe. You loose maybe 3-5 hp.
Old Jan 14, 2007 | 06:52 PM
l2edline's Avatar
is it bad to have a high flow converter installed with the stock exhaust?
Old Jan 14, 2007 | 06:55 PM
scenic's Avatar
Have you thought about the RRE rally cat? It looks just like a HFC, but it's actually a resonated test pipe.
Old Jan 14, 2007 | 07:01 PM
EVO-8-YOU's Avatar
just take your test pipe and your stock cat.. and wrap it around the test pipe.. LOL its badass
Old Jan 14, 2007 | 07:03 PM
Jakeg97's Avatar
not at all
Old Jan 14, 2007 | 07:14 PM
Danny23's Avatar
Originally Posted by Jakeg97
not at all
it would be a waste of money to install a high flow cat with a bone stock exhaust as you wont realize any power gains for the money you spent for it. You can do it with no problems but like i said you wont feel a thing as far as power goes.
