is the 6 speed worth modding?
Old Jan 13, 2007 | 09:20 PM
TurboIX's Avatar
All the stuff I read and hear makes me not want to mod the Evo. Is the 4rth gear really that big of a liability?
Who hear has actually broke their 4rth gear?
Old Jan 13, 2007 | 09:21 PM
TurboIX's Avatar
And no I dont have thousands of dollars laying around to go with the 5 speed
Old Jan 13, 2007 | 09:24 PM
3SgteGuru's Avatar
Yep i moded mine, but yeah the 5 spd is more hearty. It should be fine as long as your not continuesly ripping it. mines fine so far, http://www.nvusclan.com/images/dyno.jpg I love posting that.
Old Jan 13, 2007 | 09:34 PM
fromWRXtoEVO's Avatar
Only two people(Warrtalon and Scott from TTP) that I am aware broke their 4th gear on a 6 speed gearbox.
Keep in mind they are to my knowledge the two Evo MR owners that drive their cars the most hardcore(dragstip, autocross, road course). If I have to count how many 5 speed gearboxes failed I would truly run out of paper.
Other than that, a MR gearbox should last you forever as long as the mods aren't crazy mad.
Carlos
Old Jan 13, 2007 | 09:44 PM
TurboIX's Avatar
I was thinking more along the lines of 330-360whp. I would sure hope that is not to much power to handle.
Old Jan 13, 2007 | 09:48 PM
3SgteGuru's Avatar
I believe it should be good, Just so long as you aren't a bad driver.
Old Jan 13, 2007 | 09:52 PM
andyktlee's Avatar
Pocket Mo
The guys that broke their 4th gear on the 6 speed are hardcore track guys. They're out there wringing their Evos on the strip, road course, auto-x, or a combination of all. You won't have a problem unless you're running your Evo on some type of track event many many times. There are guys such as WarmPepsi that have a MR and didn't have their 4th gear crap out although they do track events far more than the average Evo owner.
Old Jan 13, 2007 | 09:55 PM
^^^You read my mind^^^ Bullseye.
Carlos
Old Jan 13, 2007 | 10:47 PM
TurboIX's Avatar
well that's great news. I just felt hesitant to mod after reading the horror stories.
Old Jan 14, 2007 | 12:22 AM
MRedition's Avatar
I was too, so I ended up getting the SE instead
Old Jan 14, 2007 | 12:29 AM
RazorLab's Avatar
You forgot me.
Also my buddy sean, a works sponsored car, voidhawk, and a couple others that have posted on evom.
That said, I really believe it's from heat, so on the street and non-crazy HP, it should be fine.
Old Jan 14, 2007 | 01:06 AM
TurboIX's Avatar
Originally Posted by razorlab
You forgot me.
Old Jan 14, 2007 | 01:08 AM
TurboIX's Avatar
You forgot me.
define non crazy hp. And what do you mean by on the streets? I love doing roll races with the guys.
Old Jan 14, 2007 | 02:17 AM
OldschoolEVO's Avatar
whats the final drive ratio on both those trannys? Is is even worth the change?
Old Jan 14, 2007 | 02:23 AM
clarkkent06's Avatar
your target is a non-crazy whp. The reason the 6 speed's get their *** kicked is the extended races (road races) which put lots of stress on the transmission and also the extreme temps of the tranny fluid. Some people have used tranny oil coolers and the 6 speed supposedly holds up a little better in that case. Also, the 6 speed doesn't have as much fluid in it, which is also a downside.
