Car wont start
Old Jan 16, 2007 | 03:44 PM
20lbsboost's Avatar
Car wont start
Hey guys,
Recently my car has been hard to start up when the engine is cold. I turn the key and it makes a buzzing sound, i replaced the battery but same thing happend. It took me about 5 or 6 times to start it. If i turn the car off and the car is still warm it starts up fine. The weird part is, it only does this about half the time. Any suggestions?
thanks
Old Jan 16, 2007 | 05:21 PM
heavens turbo's Avatar
might be losing fuel pressure, cold weather, ice in fuel line?, fuel, spark and compression= running engine...... ses light? more info please.....
Old Jan 16, 2007 | 05:30 PM
20lbsboost's Avatar
No ice, cold weather will make it start but its not that cold here ill pull my plugs tomorrow and ill take my car to autozone for my CEL i might be throwing another code besides the no cat. I'll see if I can figure out if i'm getting sufficient fuel. I thought it might be a faulty starter but not too sure,
Last edited by 20lbsboost; Jan 16, 2007 at 05:34 PM. Reason: left a few things out
Old Jan 16, 2007 | 06:00 PM
evil mechanic's Avatar
sounds like a starter to me
Old Jan 16, 2007 | 06:36 PM
Kerr's Avatar
Fomer Vendor
Sounds like the starter, dead batteries click, starters buzz.
Old Jan 16, 2007 | 06:40 PM
ArchieBabes's Avatar
Try push starting it. If it starts then your starter is bad. You need to get it replaced under warranty.
Old Jan 16, 2007 | 06:41 PM
purevibez's Avatar
i once dropped a nut on the starter and it got caught by the terminal. it would start fine sometimes and then it would buzz till u hit it a few times. sometimes it took more clicks than others. i would start at the starter. good luck man
Old Jan 16, 2007 | 06:50 PM
Bdub25's Avatar
This might sound weird.. But i had a system hooked up to my car, and it would make my car start sometimes, and sometime stop. I thought it was a starter and i pulled apart the engine, checked the battery, plugs, fuses, everything and come to find out it was my system hooked up wrong killing my battery. IF not, it sounds like your starter. But i just thought i'd throw that out there since anything is possible and it's happened to me before
Old Jan 16, 2007 | 06:53 PM
awd4u22's Avatar
go get ur alternator tested???.....
Old Jan 16, 2007 | 09:22 PM
badboybr09's Avatar
Hey dude, you might wanna check you starter.. The SAME THING happened to me, and i did everything from jump starting, to replacing battery, battery fluid, and all that... it turned out it was my starter... It should be located right under the car between the driver and passenger's seat, its like a little bolt, I unscrewed it cleaned it and put it back on and BAM the car started... so make sure u check that iight? let me know if u have any questions on what i did. take it easy bro.
Old Jan 17, 2007 | 01:27 PM
20lbsboost's Avatar
yeah my system is no longer workign and is hooked up directly to the battery... so ill also check that out along with the starter
Old Jan 17, 2007 | 01:32 PM
DontRevMe's Avatar
the ONLY way its stereo related is if your stereo/amps are wired to come on when the car is off.
Next time it happens, try hitting your starter with a mallet.
Old Jan 17, 2007 | 01:35 PM
20lbsboost's Avatar
the headunit goes on when i put the key in, not only if i start the car
Old Jan 17, 2007 | 01:39 PM
DontRevMe's Avatar
I dont believe its your stereo, its your starter. Stereo's dont draw more current based on temperature.
Old Jan 17, 2007 | 03:54 PM
Kerr's Avatar
Fomer Vendor
Dude, its your starter. When they go bad, they get dead spots, were they will get stuck and just buzz. If its in the dead spot, and you try turning it over, it twists a bit and gets stuck (car no start), if you keep trying, it will eventually get out of the dead spot and work, hence it working sometimes. But if you don't fix it soon, it will eventually just stop working.
