Zeitronix Help Needed pls....
Old Jan 30, 2007 | 05:01 AM
cij911's Avatar
Ok so I bought the Zeitronix ZT2 w/ Boost sensor and wired it up according to the schematic and cannot get the thing to work. Basically, when I hook up my laptop via the serial connection (Comm 1) and wait 30+ seconds, I get no data on any of the feeds (RPM, TPS, AFR, Boost, lambda, etc.). I have confirmed that the power and ground are good, but have no idea how to determine if the main unit is DOA or whether there is a serial cable issue.
Here is how I have my EVO 9 wired:
ZT2 Pin #
1 (red) – I tapped this into ECU pin # 47 wire (ignition switch)
2 (white) – don't use
3 (green) - wired this to ECU pin # 45 wire (tachometer)
4 (orange) – wired this to the Green Boost sensor wire
5 (white / blue) – not used yet, but I will wire the Alarm / Light later
6 (yellow) – wired this to the Red Boost sensor wire
7 (Black) -- ECU pin # 46 wire (sensor earth)
8 (Sensor Ground) -- ECU pin # 49 wire (power ground)
9 – not used
10 (grey) -- ECU pin # 78 wire (TPS)
11 (brown) – wired this to the Black Boost sensor wire
12 – not used
Did I use the correct sensor ground? What would cause none of the display options to show? I had planned to publish a detailed How to with pictures as none exists for the 9, but now with this issue I can't say that I am
confident with my setup. Thanks
EDIT: EVERYTHING IS WORKING FINE EXCEPT MY SERIAL PORT.....THANKS TO ALL FOR YOUR HELP.
Last edited by cij911; Jan 30, 2007 at 12:51 PM. Reason: Problem Identified -- Bad Serial Port
Old Jan 30, 2007 | 05:09 AM
Evo Girlie's Avatar
do u have the lcd screen???? and did u use a ecu pinout to make sure u tapped into the right wire????
Old Jan 30, 2007 | 05:24 AM
cij911's Avatar
No I don't have the LCD....Yes I used the ECU Pinout but frankly that is why I posted how I wired my unit to see if I made a mistake....Unfortunately I suspect that my unit is DOA....Very frustrating...
Old Jan 30, 2007 | 07:42 AM
Ph3n1x's Avatar
make sure the com port in device manager is the same one set in the program. or you may have faulty wiring or a unit.
Old Jan 30, 2007 | 12:52 PM
cij911's Avatar
Everything is working fine except my serial port. I bought the USB converter, switched to Com 6, and everything worked fine....Thanks!!
picco97
May 3, 2016 09:54 PM
Evo_AK
16
Sep 28, 2015 12:26 PM
tboboy
Aug 7, 2010 03:39 PM
TTP Engineering
May 22, 2009 09:52 PM
500whp.com
40
May 18, 2006 10:29 AM
