V1 Hardwire into sunroof relay?
Old Mar 9, 2007 | 09:57 PM
XK120's Avatar
Question V1 Hardwire into sunroof relay?
I was just wondering which wires people taped when they hardwired their V1s into their sunroof relays (I've read that quite a few have done this). Thanks
Old Mar 9, 2007 | 11:01 PM
Frenchy4g63's Avatar
I've had this done on a couple radar detectors, but never used the sunroof relay.
I've always had them ran to the ignition via fuse's.
Old Mar 10, 2007 | 03:56 AM
DanJ's Avatar
Running it through the fuse box is a mistake since it will defeat the purpose of the fuse completely and you could have a big problem down the road. I tapped mine into my headunit wiring adapter since I have an aftermarket headunit and I was required to buy the wiring adapter. That way none of the original wires are tampered with.
Old Mar 10, 2007 | 05:13 AM
Evo_Jay's Avatar
I have installed my V1 in two evos, an s2000 and other cars. I usually use an inline tap to tap the power wire going to the back of the cig lighter. Usually just ground on a bolt or screw behind the dash.
