Electronics problem (Sorry if wrong thread)
Old Mar 20, 2007 | 10:22 AM
lapkin's Avatar
Hello all,
I recently purchased a VIII and just had a weird electrical problem.
I drove for 15 minutes like normal, and parked. Came back out after 3 or so hours and many of my interrior electronics are not working. Here is a list of what works, and also what works with the ignition turned on, that didn't without.
Does not work without ignition:
Power locks
Dome light
Clock
Radio
A/C
Works when ignition is turned:
Power locks
I checked all fuzes, non were bad. I was told it could be a grounding problem, or possible a relay. If anyone has any ideas or guidance, thank you so much for your input.
Have a great day!
Old Mar 20, 2007 | 10:26 AM
DanJ's Avatar
maybe battery on the way out? I know weird things can begin to happen when the battery starts to loose it's juice.
Old Mar 20, 2007 | 06:29 PM
fastassfourdoor's Avatar
man i dont know but the same thing is going on in my car right now, but instead of not working at all, my gauges just go crazy even my freakin rpm gauge, im changing the battery out tommorow to my stock battery. i dont know what it is man but ur not alone...we should keep each other posted....
Old Mar 20, 2007 | 08:07 PM
DanJ's Avatar
My parents mercury mountaineer acted very funny when the battery was on it's last leg (rpm/speed gauge jumping up when the car was in the ignition mode). replacing the battery fixed all these problems. If you take your battery to autozone they will be able to tell you if the battery you have is bad/good that way you can atleast start to narrow down your problems a bit.
Old Mar 21, 2007 | 06:08 AM
93turbomax's Avatar
Sounds like an ignition switch or wiring to me. Do u have a turbo timer?
Old Mar 22, 2007 | 10:56 AM
PorkRoll's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=252161
This was the cause of my electrical problems as well as a few other Evo8 owners on NE-EVOS
Old Apr 11, 2007 | 09:46 AM
lapkin's Avatar
Fixed!
Thanks everyone for your input!
I took it to the Mitsu Dealership here in town. It was a main line fuze that went out, which could of been cause by a short from a loose wire in the back of the cd player... which I just had installed a few weeks before. Relatively cheap fix, only 85 bucks. That main line fuze was the one that controlled all of what I said before, the other one was more important, good thing!
Thanks again!
