Defi Gauge Pod
Old Jun 5, 2003 | 11:57 PM
bad karma's Avatar
Defi Gauge Pod
I have decided to get Defi gauges for my evo, three 60mm gauges. I just wanted to know if any manufactuers have a gauge pod for 3 60mm gauges, and if not, would the gauge pod Defi sells for the Subaru Wrx fit in the center of the dash of an evo? thanks
Old Jun 6, 2003 | 01:05 AM
N10S's Avatar
The Defi center pod is specifically designed to replace the factory subaru center pod.I suppose if you knew what was under the EVO dash(ducting wire looms, braces, etc....)and had open access you could cut a hole in the dash to accept the Defi pod. This would be an extreme thing to do in my opinion but if done by a professional could probably be made to work and look good.
I had the defi pod and 60mm link gauges in my WRX and they were an awesome package that looked so clean they appeared to be an oe upgrade. In fact I believe there is a JDM option for the hood and 60mm defi gauge pak. The defi gauges are actually silkscreened with the STi logo!
