Urgent Neeeeeddd Help Please!!!!
If only ONE spark plug caused the problem, there is a bigger underlying problem. Sounds like oil or coolant or something is getting into that cylinder (or detonation) and fouling the plug. What does the plug look like?
That is exactly what I was thinking....the plug has corrosion around the hexagon (part you ratchet) and was fouled more than the other plugs...
isnt that wierd how you install an amp and sub and right after your plugs go bad?
my freind installed an intake on his f-150 and after it wouldnt start! we jumped it and it wouldnt stay running. (bad battery) but its wierd how these things happened at the same time!.
Gl with that cylinder and glaad u firgured it out!
I think i am having the same problems as you blue by ray. I just threw in some race gas at the track and my **** started stubbling real bad at WOT. I felt the same thing like i was getting fuel cut, but i think it is the plugs. I had some NGK BRP8IEX's next day air'd to me. So hopefully i can swap them out and everything is cool.
ok heres a good one for everyone. i return my car back to stock. car runs perfect. so i change out the spark plug wires to the stock ones start up the car and it back fires and is idleing really rough. put the new ones back in with the same outcome. any ideas?
Check all connections, where the spark plugs meet the wire, and where the wires meet the coils. Spray electrical cleaner on them if necessary. Make sure that you didn't hook up anything backwards.
EDIT: Wow I didn't see that you installed an amp...thats why you are having the problems.
