Another boost problem
Old Mar 31, 2007 | 03:37 PM
cdupont03's Avatar
So I cant seem to get my evo to boost above around 12 lbs, if I keep it at half throttle it will hold around 12lbs all the way up but if I try to give it more gas it starts to sputter out. I cant find any boost leaks and the EBC is good. but around 12 lbs it just starts to cut. The car idles fine and I am not throwing any codes. My vac seems good about 15 at idle and 19 when I get off the gas. what am I missing? I hear my walbro so I assume it works. Any suggestions?
Old Mar 31, 2007 | 04:35 PM
cdupont03's Avatar
anyone? ideas.....
Old Mar 31, 2007 | 04:40 PM
whitersevo's Avatar
hmm compression check?? boost leak test? check your spark plugs, are they gapped correct? check your spark plug wires?
Old Mar 31, 2007 | 05:14 PM
Warrtalon's Avatar
Change your plugs. NGK BPR7ES gapped to .026.
Old Jul 6, 2007 | 11:35 PM
subrwho's Avatar
Order new oem plug wires. I just fixed the exact problem you had by changing them (well, the sputtering anyways)
