WhiteEVo got dirty....
ok, i washed and waxed my EVo the other day, went driving around. GOt home, notice i got some dirt marks on both sides of my car. I thought it was nothing of it, because it looked like mud specks from the road. As i try wiping it off, it ain't dirt/mud, its like grease or something, its not comng off
i bought bug/tar remover, used it, and it does not clean it off totally, **** is pissing me off.
what the hell is it?!?!??!? is it oil? its like brown, after i use the remover, its like yellowish now...sigh.
If it is infact some kind of oil or grease, try wiping it off using a cotton fabric such as a white HANES T-shirt. If it is grease, it should come off. If it doesn't, use NU FINISH car polish. I can almost guarantee you 100% that it will come off. You use it like wax. Apply a small amount of polish on a cotton shirt and rub that grease/dirt in a small circular motion and use a clean side of the cotton T-shirt to buff it clean. This should work.
**** NU FINISH! thats the best way to scratch a nice new paint job in short order. spend 10 bucks and buy clay magic or any of the clay / lube based cleaners.
http://www.clay-magic.com/
be nice to your EVO's no washing with dish soap either !
Guest
Posts: n/a
Yes, if it's black and turns yellow, it's most probably tar.
The thing is, you have to leave the tar remover on it for 30 seconds or a minute and then wipe it off, not spray and wipe immediately. Not saying you didnt do it right, but I found that out after trying
Re: WhiteEVo got dirty....
Do not use polish to remove tar. Polish is meant to cut the paints surface and remove scratches....it is not meant to remove caked on dirt and tar.
Use a Clay bar.
While clay bars are abrasive, like polish, it is a much finer abrasive.....and in the end it's the shearing action of the clay againts the body of the car that removes the tar, not an abrasive action...as would be the case if you used car polish.
These cars are brand new guys. We shouldn't have to use actual abrasive polishes on the paint for some time.
SC~
Use a Clay bar.
SC~
Good luck taking it out. A good cleaner wax should take it out. Or you could try WD-40, but the wax should be sufficient.
