!!!!!! SES after a night at the track??
Old Apr 7, 2007 | 11:37 PM
stikillller's Avatar
Hey guys, has anyones SES light come on after a night at the track, a few runs??? I have a TBE [no cat] but a mechanical o2 fix, mbc, drop in, and a tune from TT. Anyone? I'm thinking it is just my o2 sensor, hopefully i'm right, thanks for the replys in advance!
ok so it is the p0011, Cam timing. Did a little research, and it seems it is due to my tune and something with mivec????? I have STOCK cams. So, anyone, should I be worried about it or just clear it and forget about it? Thanks.
Old Apr 7, 2007 | 11:38 PM
evo150's Avatar
get it scanned. it could be alot of things. how long ago did you install the o2 fix?
Old Apr 7, 2007 | 11:40 PM
yeah i was just about to say i don't know the code yet, i've had the o2 fix for about 8 months now. But i'm so **** and just worried and hoping it isn't anything big. >.<
Old Apr 7, 2007 | 11:43 PM
Nvr2old32's Avatar
Welcome to the modding path! You'll get use to the lights!
Old Apr 7, 2007 | 11:53 PM
yeah, i mean i've had the ses light before and it was right after i installed my tbe, hopefully it is the same this time, btw, ironic that it had to come on after i walked a STI with stage 2 cobb [not that big of a deal, just saying] hhhahaha.
Old Apr 7, 2007 | 11:55 PM
evo150's Avatar
if youve had the o2 fix for 8 months i doubt the ses light is that. well see though
Old Apr 8, 2007 | 12:01 AM
CRAPPPPPPPP -.- I REALLY hope you're wrong!! btw, are you wrong alot of times or no -.- hahahha
Old Apr 8, 2007 | 09:18 AM
thatguy's Avatar
Run the code, could be a lose connection? Maybe 02 sensor got loose, etc.
Old Apr 8, 2007 | 09:30 AM
chitown_EVO's Avatar
could have been bad fuel, or it was running a little lean. i used to have mine come on every once in a while if the fuel wasnt fresh.
Old Apr 8, 2007 | 09:36 AM
lancersibling's Avatar
get it checked at Auto Zone for free. If you got ot the dealership, they will read the code and gather the stored information in the ECU on what the car was doing when the light tripped. Letting the dealership know it tripped at 100+mph probably isn't a good thing. It could be a number of things but not likely the O2 fix. I've been running the fix for abot a year with no light. Good luck!
Old Apr 8, 2007 | 09:37 AM
kdwg927's Avatar
Did you use race gas?
Old Apr 8, 2007 | 09:43 AM
Warrtalon's Avatar
If you haven't checked the code, then making this thread was a waste of time. When you get a code, the first thing you do is check it to see what it is. We aren't clairvoyant - how can we know what the problem is or may be if we don't know the code??
Old Apr 8, 2007 | 12:00 PM
90GSX-03EVO's Avatar
ASSuming that you're running spark plug anti-foulers to trick the O2 sensor?
ASSuming that you used leaded race fuel?
ASSuming that even though the anti-foulers were installed, the leaded race fuel was still enough for the O2 sensor to pick up? Track nights are usually mostly WOT runs, so maybe you just did a good "shake down" of your car and problems started appearing that would have normally been exposed during daily driving.
I can keep on ASSuming all day long, but until you post up some true facts as to what all of the variables are, it won't do much good.
Old Apr 8, 2007 | 12:38 PM
ok updated, anyone care to chime in? Thanks.
Old Apr 8, 2007 | 12:43 PM
Warrtalon's Avatar
The p0011 can be caused by advancing the intake cam timing significantly, and it's apparently not a worry, but it's up to your tuner to change the ECU settings so that it doesn't pop up again.
