Need 'Circlip' ASAP
Need 'Circlip' ASAP
My t-case is arriving in less then 2 weeks and my dealer just informed me that the circlips (snap ring on the output shaft) need to be changed and won't arrive for another 60 days.
Link below shows that i'm talking about (no.13)
https://www.evolutionm.net/forums/sh...hlight=circlip
Anyone know where i can order this part online?
Better yet, is this part universal? will i find it in a regular front wheel drive lancer?
Part number is MB160387
thanks
thanks
If you search in the "how-to" section there is a thread showing a the steps to do your own clutch. The OP talks about those circlips and how they are the same as the ones on an older Eclipse or something.
Found the link
https://www.evolutionm.net/forums/sh...ghlight=clutch
The snap rings (CIRCLIP) on the shafts are the same as a 90-94 Eclipse driver or passenger axle snap ring, the only reason I am including this is because we had to search for this replacement when the dealer couldn't get us this ring the same day, we happened to break one during the re-install, and this was the easiest way to replace the snap ring, we just returned the axle minus the ring. It helps to have a friend at the parts store.
