Radio power wire
Old May 26, 2007 | 11:42 PM
Thoe99's Avatar
Radio power wire
Does anyone have a diagram that points out what the wires are for the radio harness? I'm specifically looking for the power wire that turns on with the key, not a constant power. I need to tap into it for an accessory install.
Old May 27, 2007 | 12:39 AM
b00stin evo8's Avatar
on an aftermarket radio harness it would be one of the blue wires with an REM label which is used for a remote turn on wire for the amp only when the key is in. Thats what you need, for the factory radio installdr.com was blank. So..... it would be alot easier if you have an aftermarket radio. Good Luck
Old May 27, 2007 | 05:40 AM
bmfgsxr's Avatar
while this question is up i recently got my ix and it has an aftermarket system in it.. when i turn the key to accessory i get no power to the radio or the windows. what would i need to do to correct this? i think its safe to assume that if this was the factory installed radio and no wires were touched i wouldnt have this issue.
Old May 27, 2007 | 08:25 AM
Thoe99's Avatar
It's for a factory radio. Anyone else know the answer?
