walboro install help
Old May 29, 2007 | 06:25 PM
03SilvaEvo's Avatar
OK got the pump out of the housing but I accidently pulled a little too hard on the pump and the terminal crimp fits came out of the GREY connector. I need to know which wire goes where. My guess, according to the pics on evo moto, is the blue wire goes closest to the tab.
Is it necessary to put the black sleeve on the pump before sliding back into the housing?
Old May 29, 2007 | 06:58 PM
Redline-Z's Avatar
Veteran: Air Force
look at the Evomoto pics, It is what I used and no the sleeve doesn't have to be installed. It might quiet the pump down but I couldn't get mine back in the housing with it on so I cut it off the pump. Now it whines louder and I know its working
Old May 29, 2007 | 07:50 PM
TunerHead24's Avatar
lol
Old May 29, 2007 | 07:58 PM
KartaRailed's Avatar
Just guess and check. Thats what I did, and somehow it took me 4 trys.
Old May 29, 2007 | 10:03 PM
03SilvaEvo's Avatar
Connections complete and pump to housing install is done. The only thing thats a PITA with this install is that damn retaining ring! Now I gotta fiddle it in there
Old May 30, 2007 | 06:19 AM
belizelittle39439's Avatar
I found absolutely nothing about the install to be difficult. Do what the evomoto site says and you should be golden. The retaining ring, once you get it on, just use a small socket (I used like a 4 I think) to tap it down. I also resused the stock top hat as well.
Old May 30, 2007 | 06:29 AM
Smike's Avatar
http://evomoto.com/tech_info.php?tPa...510b234dc290e7
Here is the link to the site^
