Perrin Meth Injection Kit Primer Pump.
I was wondering if ya'll knew a good primer pump to use for the Perrin PWI-1 Injection kit? I HAVE tried both the stock intercooler pump and stock Windshield washer pumps and the "low flow" light comes on with both. So I guess those pumps cannot supply enough fluid for the much bigger Perrin pump. I've read that if you do not have a primer pump it flows somewhere around 380cc/min but with a primer it can flow around 560cc/min. with my setup I feel I would need a primer pump because of how much boost I'm planning to run. which on race gas would be somewhere around 35-36lbs on a gt35r setup. So on Meth it should be a bit lower. Please help!!! my tune is coming up in a few days
