Installing Zeitronix and destroyed my car, need help ASAP.
Old Jun 7, 2007 | 09:38 PM
sleet's Avatar
I recently installed my Zeitronix unit including the wideband o2 sensor and the LCD monitor. The install was easy and has been running for about 2-3 weeks now. Just recently I ordered the Boost MAP sensor and the ZAVT-1 alarm. I installed the Boost sensor first and went for a drive, everything ran just the way it did before. Then I began to install the ZAVT-1 alarm, this is when everything went wrong.
I tried to start the car after finishing the wiring for the ZAVT-1 and it could barely idle and eventually shut off. I threw several engine codes including:
DTC P0118: Engine Coolant Temperature Circuit High Input
DTC P0123: Throttle Position Circuit High Input
I then removed the Boost sensor, ZAVT and even unplugged the Zeitronix but the car still runs terrible. Now I can't drive the car anywhere and i've got no idea why I threw these codes. It's weird because I didn't touch anything in the engine bay and I have no idea what these codes even mean. If anyone has any experience with these codes or knows how to resolve this issue I really could use the help. Thanks.
Old Jun 7, 2007 | 09:51 PM
Ph3n1x's Avatar
Did you program the alarm? nvm you removed it.
Did you unplug the maf? What pressure are you reading on the boost gauge at idle.
Old Jun 7, 2007 | 10:09 PM
sleet's Avatar
No I didn't touch the MAF at all.
Idle is between -7 to -4.
I also just checked and theres another code in there now:
DTC P0132: Heated Oxygen Sensor Circuit High Voltage [SENSOR]
Old Jun 7, 2007 | 10:14 PM
gobagheera's Avatar
I have the ZT-2 with the boost and alarm. Never had issues that you are describing. I don't see how the boost or the alarm could cause these codes. I would check your ecu connections to ensure that they are secure and that there isn't an electrical ground on your wires that shouldn't have them.
Old Jun 8, 2007 | 05:29 AM
sleet's Avatar
Almost 100 views, anyone?
Old Jun 8, 2007 | 05:31 AM
Evo Girlie's Avatar
^ try Pming Scott or calling him maybe he can help since he is the main ZT vendor
Old Jun 8, 2007 | 05:38 AM
Kerr's Avatar
Fomer Vendor
Where did you tap for the wiring? Was it at the ECU? If you have loose connections/wires crossed/wires touching it will throw codes. Maybe try going back over all the wiring and make sure its right.
Old Jun 8, 2007 | 05:56 AM
dudical26's Avatar
Most likely you have accidentally crossed or disconnected some wires at the ecu. Please review your wiring installation to make sure it is correct and that there are not any other damaged wires.
Old Jun 8, 2007 | 05:58 AM
MalibuJack's Avatar
Definitely sounds like one of the ECU connectors isn't seated properly, most of the sensors your describing having an issue all share the same connector.
Old Jun 8, 2007 | 07:19 AM
TTP Engineering's Avatar
Without any pics or descriptions of connections to pins it will be hard to determine. Sounds like Jack is pointing you in the right direction. My vote goes to an improper connection / ground.
TTP Engineering
EvoX 'For Sale' Interior Styling
18
Dec 1, 2009 12:45 PM
TTP Engineering
Evo 'For Sale' Electronics / Lighting / Audio
16
Jun 25, 2009 08:47 AM
BadazzCR
Aug 23, 2008 07:40 AM
CharlieGsanD
Nov 8, 2004 10:00 PM
