Quick question regarding MBC..
Old Jun 29, 2007 | 10:03 AM
heSOshAdy's Avatar
Hey guys,
On my car I have installed a Halman MBC and I didn't have the "C" shaped clamp that comes with it. Currently I have it just zip tied to the stock intake brackets (not stable, and will move around) and I noticed that my boost seems to drop 2~4 psi immediately after I hit peak boost (22psi). It seems to hold boost better in 4th and 5th, but 1-3rd it tapers to around 18psi. Am I seeing this drop in boost because the MBC is not stable? or should I be looking for a boost leak somewhere? Does anyone know where I can pick up the "C" clamp anywhere? Thanks!
Old Jun 29, 2007 | 10:07 AM
CRX2EVO's Avatar
normal
Old Jun 29, 2007 | 10:08 AM
Warrtalon's Avatar
Errrr, no. That's how boost works. More load in higher gears = less taper and higher boost. Less load in lower gears = less boost and more drastic taper The taper is not caused by the MBC not being mounted.
Old Jun 29, 2007 | 10:41 AM
travman's Avatar
Def. normal....Up until 2 weeks ago when I finally took the time and mounted it my mbc just hung from the uicp with a zip tie around the one vac. line, doesnt have to be mounted or "stable" to work properly.
Old Jun 29, 2007 | 10:43 AM
heSOshAdy's Avatar
I'm sure you guys are right, but it just seems like I'm leaking somewhere because when I had the bracket/clamp on it didn't drop so quickly...but then again that was my Evo 8...
Warr, are you still using your stock air box?
Old Jun 29, 2007 | 10:48 AM
Warrtalon's Avatar
No, I have a Buschur intake. My Forge UNOS is mounted right on one of the intake mounting brackets. When I used to use my Hallman, I had it mounted on the radiator connection just below the intake snorkel. Since it was black, it was almost undetectable, but I had the c-clamp you are missing.
Old Jun 29, 2007 | 11:33 AM
travman's Avatar
IX's have more taper than the VIII's.
Old Jun 29, 2007 | 11:45 AM
prj.evo's Avatar
I have gotten my 8 to hold exactly 22psi (1.5 bar) with the hallman MBC. Mounting it has no effect on boost though. Unless you confuse the lines or something.
Old Jun 29, 2007 | 12:00 PM
evo150's Avatar
lowes has the same bracket that comes with the hallman. in the isle where the stainless bolts are, youll see where they have bracket hardware and stuff. they have a couple different sizes but they even come with the rubber on them just like the hallman bracket.
