UPDATE on my car!!
Old Jul 10, 2007 | 06:11 AM
  #46
Warrtalon's Avatar
Originally Posted by subrwho
Testudo, you the man!!!
I looked at that thread that you posted, went out and found the line disconnected! I re-connected it, now I am goinna go buy some new spark plugs (because in that thread it said it could foul them) and then i'll reset my ecu. Maybe my ecu is in safe mode? and thats why I cant boost?
No, dude, there is no safe mode if your stock BCS isn't connected. Think about it...how would the ECU limit your boost if it's not connected to the boost system?
Old Jul 10, 2007 | 06:13 AM
  #47
subrwho's Avatar
Damn just spoil my hopes why dont you Warr lol
Old Jul 10, 2007 | 06:14 AM
  #48
TeStUdO's Avatar
Is it possible that thats the reason why I cant boost over 12psi? I went for a drive just now (to get food) and still couldnt get past 12psi, But I also only took the neg. battery cable off for 30 seconds. . .
Did you ever try adjusting your wastegate? Try turning it a few times to adjust the pre load? I am just grasping at this point because I am stumped.
Old Jul 10, 2007 | 06:17 AM
  #49
subrwho's Avatar
Yep I have ^
And i'm running open wastegate right now and still cant pass 12psi. .
Even when I run the mbc on there with it set to low boost I run 12psi.
I am stumped!!!!!!
Old Jul 10, 2007 | 06:20 AM
  #50
TeStUdO's Avatar
Boost leak.....check
Wastegate....check
Boost gauge..check
EGR Valve......check
MBC...............check
Im felted man, out of ideas
Old Jul 10, 2007 | 06:22 AM
  #51
subrwho's Avatar
Me too
I'm really starting to give up. . . I've met up with 4 other people and they are stumped too. . . I mean I have tried pretty much everything!! And I have spent quite a bit of money ordering parts to try and find the problem
Old Jul 10, 2007 | 06:24 AM
  #52
subrwho's Avatar
what really gets me though, is that whether I run an mbc at high setting or low setting I run 10-12psi. And when i'm running an open wastegate (which should go well over 30psi) I run 10-12 psi
Old Jul 10, 2007 | 07:11 AM
  #53
Warrtalon's Avatar
Might be a problem with the internal wastegate itself, which is inside the hotside.
Old Jul 10, 2007 | 07:19 AM
  #54
Evoryder's Avatar
did he change his boost gauge? or test another gauge with tubing? I am assuming short cuts or you are missing something obvious...
Old Jul 10, 2007 | 07:26 AM
  #55
subrwho's Avatar
Lol tried that, bought a new 10.5 hotside. . .same problem. .
Old Jul 10, 2007 | 07:31 AM
  #56
bvdawg13's Avatar
did you change the spring in the mbc?
Old Jul 10, 2007 | 07:32 AM
  #57
mot's Avatar
mot
did you happen to get the hotside coated or anything at any time?
i got mine coasted it made the flapper sticky and this made TONS of boost issues
also if the flapper is broken or missing youll only run wastegate pressure ALL the time
next time you check the car take the wga arm off the hotside and manually move the flapper see if you can hear it moving inside or if it moves weird
at this point this is the only thing left in your entire boost equation
EDIT saw you bought a new 10.5 hotside
this is out of control
Old Jul 10, 2007 | 07:36 AM
  #58
subrwho's Avatar
Nope it was never coated. . It sounds just as it should. . .
As far as the mbc, i've tried 3 different boost controllers, and ran open wastegate. . Same thing everytime . . 12psi. . . And the wastegate is an FP wastegate adjusted to the "high setting". (and yes ive tried lowering the preload, and raising it, didn't help.)
Old Jul 10, 2007 | 07:39 AM
  #59
subrwho's Avatar
Just a reminder that I remembered today: I had a turbo xs mbc hooked up (wrong) and i'm not sure what or if that could have caused this problem. . But one day at the track I couldnt get over 13-14psi, so I tried open wastegate. . same problem. . then about 3 days later I couldnt get above 6-8 psi (so we assumed bad wastegate)
-Changed the following:
new wastegate
new manifold
new o2 housing
new 10.5 hotside
new boost controller(installed correctly lol)
new plug wires
new plugs (4 times in the past two months just to test)
Old Jul 10, 2007 | 07:40 AM
  #60
bvdawg13's Avatar
try putting the stock bov bak on
