Running without the airbox lid
Old Jul 7, 2007 | 07:17 AM
SuprEVO's Avatar
Exclamation Running without the airbox lid
Im pretty new to the evos and turbo cars and was wondering does anyone run there EVO without the lid for the airbox? Do you think it would make it run better or not? (give it alittle more HP or pretty much just make it louder?)
Old Jul 7, 2007 | 07:19 AM
LoCo4's Avatar
You can, I have seen it done. Works okay, but looks really bad when you open the hood.
Best bet is get an intake.
Old Jul 7, 2007 | 07:34 AM
Tarmac_IX's Avatar
i tryed it but did nothing
Old Jul 7, 2007 | 07:53 AM
SuprEVO's Avatar
do you think it made your car slower?
Old Jul 7, 2007 | 08:10 AM
ak47po's Avatar
Why do you really think Mitsubishi engineers put a cover on in the first place,because they had some extra ones laying around.
Old Jul 7, 2007 | 08:13 AM
Ride927's Avatar
to make it carb legal?
Old Jul 7, 2007 | 08:15 AM
Mmelmann's Avatar
It wouldn't hurt much other than the fact that you'd be ingesting a little more hot air vs the cooler air that is snorkeled in from the outside of the engine bay. Also, the stock airbox directs even more airflow once you are actually driving (which is the whole point of owning a vehicle). The stock airbox was designed for with performance in mind... we are talking about Japanese performance engineers afterall, not Buick or Ford engineers.
If you look at top performance car manufacturers like BMW, Porsche, Mitsu, Ferarri, etc. they use some sort of ram air design concept for their airboxes so I would figure that they know what they are doing. The idea is to get the most cool (i.e. dense) air to start the whole combustion process and the ambient air outside of the engine bay is better than the less dense and turbulent air that's inside the engine compartment.
That said, if you look at the stock airboxes of some cheap mass produced cars you'll see that the intakes are a source of restriction... as in the incoming air has to be almost sucked through an airbox with a small opening. I don't think this is the case for our Evo's airbox. It may not be the most efficient at 0 mph of airspeed, but it is definately more efficient at getting cooler air directed to the air filter once the forward airspeed picks up.
I'm pretty sure you already know this.
Old Jul 7, 2007 | 08:42 AM
EvoSid's Avatar
Nicely put.
Old Jul 7, 2007 | 09:03 AM
EvoJoeIX's Avatar
i run mine without the lid....
doesnt really make a difference excpet for the turbo is a little louder...
oh yea, it gets your air filter real dirty, real quick
Old Jul 7, 2007 | 09:42 AM
Jakeg97's Avatar
probably make it run worse (less power) as its taken in more warmer air
Old Jul 12, 2007 | 12:36 PM
ajbreezay's Avatar
lot more dirt in there with it off! Just buy a aftermarket one!
-Aubrey
Old Jul 12, 2007 | 06:28 PM
cmj's Avatar
cmj
Read this.
https://www.evolutionm.net/forums/sh...ghlight=AIRBOX
Old Jul 12, 2007 | 06:39 PM
deegaw11's Avatar
i've done it before, sounds alot better but definitely runs slower. i got sick of the sound and put the lid back on.
Old Jul 12, 2007 | 06:41 PM
bluebyu36's Avatar
it's proabaly pulling timing..
Old Jul 12, 2007 | 06:44 PM
1320 Engineering's Avatar
pulls timing, causes engine to run rich, killing your gas milage
