speed density / maf
Old Jul 7, 2007 | 04:34 PM
thedragon's Avatar
speed density / maf
what is the difference between speed density and maf what r the advantages? please advise
Old Jul 7, 2007 | 07:10 PM
Tuner@Swift's Avatar
Speed density is a method of calculating air volume based on pressure and temperature. A MAF sensor calculates air volume based on air temp, barometric pressure and metered airflow either from a hotwire, flapper or karmann vortex generator.
The advantages of using a speed density setup is being able to use a VTA BOV, get rid of the MAF sensor that could be a restriction, be able to drive somewhat normally even with the I/C piping completely blown off. Your only options for converting to speed density include AEM EMS, MAFT Pro or a patched ECU in conjunction with a JDM MAP sensor.
A MAF setup is easier to work with and tune.
Old Jul 7, 2007 | 07:34 PM
Top_End_EVO's Avatar
if you want to have more than 600hp-700hp you have to go speed density. I think the most someone did on maf is 550hp or somewhere around there...
Old Jul 8, 2007 | 12:45 AM
evilevo22's Avatar
is there a cheap way to set up a speed density setup
Old Jul 8, 2007 | 04:17 AM
dsmfan95's Avatar
Right at 600whp with a GM MAF and stock ECU.
Old Jul 8, 2007 | 11:09 AM
thedragon's Avatar
thanks guys
maxspeed96ct
Northeast Region
Aug 22, 2016 11:08 AM
KJS
Dec 5, 2015 06:48 PM
bluedemon199
Dec 3, 2015 04:07 AM
elkazX
Feb 27, 2015 08:21 AM
KY
Sep 20, 2007 08:25 PM
