Accessory (ACC) Fuse
Old Jul 10, 2007 | 07:11 PM
Sr20kidD's Avatar
where can I find this fues. At the moment, My radio doesn work, nor my Dashboard clock, I checked the fueses behind the headlight switch adjuster, and also the ones in the engine bay on the driver side. Am I missing any more?
Radio powers up and I could eject the CD's but thats about it. It doesn actually fully power up.
Old Jul 11, 2007 | 01:36 AM
DRPTPGT's Avatar
sorry man...idunno
Old Jul 11, 2007 | 04:38 AM
Speed Corps's Avatar
Former Vendor
Did you just recently wire up something new? If so, re-check your wiring. For the radio to power up like that, it wouldn't be a fuse.
Old Jul 11, 2007 | 04:47 AM
KawRider's Avatar
The radio fuse is in the main fuse box in the engine bay. The lid has a diagram of what fuse powers what. If you recently had the radio out to work on something, maybe your antenna wire is loose? Stupid mitsubishi uses the antenna wire as the ground. But that wouldn't effect the clock. It easy to tell if a fuse is blown by looking at it, it will be burned on the inside of the clear plastic. GL and keep us posted.
Old Jul 11, 2007 | 06:59 AM
Wallesasuaz's Avatar
recheck your fuses... if they're okay..
Its definitely one of the fuses concealed in the front.
Old Jul 11, 2007 | 07:04 AM
Former Vendor
How can the radio partially power up if the fuse is blown?
Old Jul 11, 2007 | 07:09 AM
rcheung's Avatar
That happened to me a while back on another car. The acc fuse blew but the constant power fuse was ok so the radio would light but not turn on. It depends on the radio.
Old Jul 11, 2007 | 07:28 AM
Former Vendor
No kiddding? That's why I leave the stereo stuff to the experts. Then I agree, re-check your fuses. If it was just the radio, then I'd say maybe the radio is screwed up. But since your clock is affected, it's gotta be a fuse.
Old Jul 11, 2007 | 08:27 AM
Sr20kidD's Avatar
I re-checked the main fuse box again, removed all the fuses and checked the one by one. I went as far as removing the bezel and removing the clock to see if there was any other hidden fuses, nothing. In the fuse box, there is one that is empty which shows "radio", but in between where the "prongs" would normal go there is a tab indicating that there was never a fuse there. Weird, I dunno, im thinking of putting my stock radio back and removing my TT and Gauges and seeing if the dealer would fix it under warranty...
TIA guys
Old Jul 11, 2007 | 08:51 AM
Former Vendor
Check your wiring again. Make sure you have a solid ground. If you shared any of the wires with the radio, that could be your problem.
Old Jul 11, 2007 | 09:51 AM
goBYeBYe's Avatar
Check and make sure your antenna is plug in as well. Even something as simple as that can cause some issue like you described.
keep us posted.
Old Jul 11, 2007 | 09:59 AM
SaOrlando's Avatar
it wouldnt eject at all if the antenna wasnt plugged in.
its definitely the accessory lead
either the wire is burnt out or the fuse is bad. change that fuse anyways,
many times they are bad, and look fine.
Old Jul 12, 2007 | 12:55 AM
Sr20kidD's Avatar
alright, i'll tackle this tomorrow as i didnt have time tonight. I'l let you guys know.
Old Jul 24, 2007 | 07:41 AM
Sr20kidD's Avatar
alright update, checked all my fuses and all are in working order. took a fuse checker and also a MM and found continuity on all fuses.. I also found out that my rear whiper isnt working .
So could it be a relay?? i will next disconnect the battery and it should reset everything... I dont want to take it to the dealer.. COME ON PEOPLE THINK!!!
Old Jul 24, 2007 | 07:56 AM
TouringBubble's Avatar
Did the problem surface right after installing either the radio or gauges?
