Help Diagnose this sound [VIDEO]
Old Jul 19, 2007 | 04:58 PM
laakness's Avatar
I had my timing belt/balance belt and all pullies/tensioner replaced a couple months ago. The alternator was also replaced.
Ever since a week after the install there is a high pitched "zzzzzzzz" sound that increases and decreases as the RPM's do.
We tried a different serpentine belt and the sound is still there. When we changed the belts we did notice the water pump had a spot of dusty/dried anti-freeze which must have leaked out.
I've never had any drips of fluid under my car though and the belt is always dry when I check it after driving.
Any suggestions on what to try to help narrow this down would be much appreciated.
http://video.google.com/videoplay?do...69092108818208 - turn down your sub if you have one while watching.
Thanks
EDIT - The sound is always the same...it hasn't gotten worse...even after multiple 4th gear pulls for my TTP flash. It's just annoying as hell.
Old Jul 19, 2007 | 05:18 PM
bmguser's Avatar
just a guess but have you tried using (i forget what its called) something like a stethescope to see if you can point the origin of the sound?
Old Jul 19, 2007 | 05:20 PM
darkstar6069's Avatar
I had the same thing and it was acutally just a rusted gear that was squeaking but who knows
Old Jul 19, 2007 | 05:26 PM
TTP Engineering's Avatar
It appears your Tbelt tensioner is overtightened and out of range of where the autotensioner can do anything.
Old Jul 19, 2007 | 05:42 PM
laakness's Avatar
Thanks Scott. I'll talk with Nick and see if he can adjust that for me.
Old Jul 19, 2007 | 07:09 PM
laakness's Avatar
What are the negative ramifications of driving like that?
Old Jul 19, 2007 | 07:38 PM
Wearing out your oil pump as it is yanking up on the sproket with too much force.
Old Jul 20, 2007 | 08:04 AM
bolsen's Avatar
Tension... or perhaps an out of aligned pulley.
Old Jul 20, 2007 | 08:24 AM
laakness's Avatar
Thanks guys, that helps a lot. I'll be having it looked at/adjusted soon.
Old Aug 4, 2007 | 03:07 PM
laakness's Avatar
Nice work TTP, you nailed it from half way across the country We loosened the timing belt some and the noise is almost completely gone. I'm ok with a little noise, most can't hear it since they aren't used to listening for it.
Old Aug 4, 2007 | 06:29 PM
Vigman's Avatar
Not sure but I also heard like a shaking noise on post accel. Any screwed screw vibrating?
Old Aug 5, 2007 | 08:00 AM
laakness's Avatar
Probably my engine dampner or the solid front motor mount causing vibration.
mekis13
Sep 12, 2016 11:44 PM
ksevo8
Feb 22, 2012 12:32 AM
Jsocpro20
Jan 30, 2012 11:48 AM
iziegsx
Jul 29, 2011 11:59 AM
PiNG
Australian Forum
Jul 4, 2006 05:55 AM
