ACT street clutch break in
Old Jul 23, 2007 | 05:28 PM
PorkRoll's Avatar
I just had an ACT street clutch installed. I found posts about breaking in clutches, but I still have a question. The standard milage for breaking in a clutch is 500 miles of city driving. But what it really depends on is how many times you engage the clutch right? I am going to be in NYC this weekend, therefor the clutch is going to be engaged and disengaged ALOT while driving in traffic. Sould I still use the 500 miles as a bench mark? I don't want to have a clutch installed again any time soon. Thanks guys
Old Jul 23, 2007 | 05:32 PM
evrblazin's Avatar
nice going to rock the bells? heh
If i were to break in a new clutch one of the last places I would want to do it is NYC
I would do 500 normal to lite use miles on it (thats just me tho).
Old Jul 23, 2007 | 05:37 PM
Speed Corps's Avatar
Former Vendor
I have the act clutch. I broke it in for 800 miles, stop and go and highway. I've had it for about four thousand miles now and it is noisy as hell. It holds fine but the noise drives me nuts. It sounds like rocks rolling around inside the housing.
Old Jul 23, 2007 | 05:39 PM
TunerHead24's Avatar
800 city and highay sounds good.
Old Jul 23, 2007 | 05:49 PM
sonicnofadz's Avatar
I'll bet you $50 my exedy twin makes more noise. Drives me bonkers. Anyways, the answer is YES. What actually wears in the clutch, is the actual slipping of the clutch (engaging from a stop). This slipping heats up and rubs the clutch against the flywheel, which is spinning at a different speed. Its up to you, but I'd be willing to say 100-250 miles of stop and go traffic is enough to properly bed in any clutch. Have fun! Hope your left calf doesn't double in size
Old Jul 23, 2007 | 06:20 PM
PorkRoll's Avatar
re
I get the car back tommorow. Should i expect a big difference in the tension of my clutch pedal?
Old Jul 23, 2007 | 06:25 PM
dentsportgarage's Avatar
The pedal will be a little stiffer than stock. You made a good choice that's a good clutch. Break in should be complete in 500 miles. It probably doesn't even take that long but there's no way to know for sure so best to play it safe. Just don't launch the car off the bat.
Alex
Old Jul 23, 2007 | 06:32 PM
sharkm87's Avatar
i broke mine in about 400 miles, then did some "spirited driving"...no hard launches till a lil later ...very jolty when you first pull off, take gettin used to like any new clutch
Old Jul 23, 2007 | 06:37 PM
dazed01's Avatar
I'm not saying that it is the best way but I drive the cars I put clutches in the same as I alwasy do. No break in period for me.
Old Jul 23, 2007 | 06:53 PM
CrackerJackToy's Avatar
I bought my car used and believe I have this same clutch. It is noisy, & I hate the noise... but it grabs real fast & hard. I had the AWD launch down on this car in 2 launches. Didnt take long to get used to & I do recommend.
Old Aug 2, 2007 | 01:58 PM
Arsenal-'s Avatar
I feel your pain corps
Old Aug 2, 2007 | 02:08 PM
bluebyu36's Avatar
my act clutch is very quiet
Old Aug 2, 2007 | 02:16 PM
big_huff's Avatar
When i had my ACT clutch put in, after the break in period i would get on it and anytime after 6,500 rpm the shifter would stay in gear. and wouldnt let go until after the rpms drop. but after a 1000 or so more miles of just normal driving it went away and shifts with no problem.
Old Aug 2, 2007 | 05:16 PM
k20ep3's Avatar
It took my car about 700 to 800 miles to break in my cluch. I drove it very easy and smooth.
Old Aug 2, 2007 | 05:20 PM
VTECH8TR's Avatar
HUHH, What does living in NY have to do with anything.. LOL..
Yeah just drive it normal and don't go crazy on the boost for the first 500 miles.
You want to make sure the clutch surface mates with the flywheel without hotspots.
