evo problem
Old Jul 29, 2007 | 08:58 AM
rinio 25's Avatar
evo problem
grinding noise out of back left wheel have changed wheel bearing and outer cv joint but when i take the abs ring out the grinding stops but then the abs and ayc light comes on need help car for sale evo 7 on way this problem is on evo 4
Old Jul 29, 2007 | 11:09 AM
heavens turbo's Avatar
LOLOLOLOLOL. good one. made me laugh. you should not take the abs ring off. it shouldn't even have came off. probably the backing plate for the rear brakes are hitting? i have had some that are warped and they contact the rotor. if you already changed the bearing, then look for signs of unusual wear.
Old Jul 30, 2007 | 03:53 AM
rinio 25's Avatar
evo problem
have looked for wear but dont see any and the abs ring was wore all the teeth on it were grinded off thats why it came off
