ingalls stiffy????????
Old Aug 8, 2007 | 02:53 PM
stikillller's Avatar
i've heard so many good things, anyone know where i can get one!? I want one please!
Old Aug 8, 2007 | 03:05 PM
WWNJIX's Avatar
Check AMS or lancershop.com for starters.
Old Aug 8, 2007 | 04:20 PM
CrackerJackToy's Avatar
Go with the frount motor mount. I too was going to go with the ingalls but decided to go with the motor mount instead. Plus the motor mount is 1/3 the cost
Old Aug 8, 2007 | 04:23 PM
ak47po's Avatar
Speedelement,don't buy from lancershop.
http://www.speedelement.com/index.ph...mart&Itemid=38
Old Aug 8, 2007 | 08:48 PM
JDMCT9MR's Avatar
I think Z1 Auto carries it.
Old Aug 9, 2007 | 09:03 AM
awr's Avatar
awr
+1 if daily driven
Old Aug 9, 2007 | 07:04 PM
boostedwrx's Avatar
I'll sell ya my Stiffy.
Old Aug 9, 2007 | 08:21 PM
evo150's Avatar
ive heard so many bad things. like others have said it is a better choice to get a front motor mount.
Old Aug 9, 2007 | 08:58 PM
liquidh's Avatar
Enlighten us, what have you heard?
Old Aug 9, 2007 | 09:55 PM
evo150's Avatar
here is a quick one https://www.evolutionm.net/forums/sh...eaking+ingalls i debated between the ingalls and a urethane mm and while searching the different types of mm alot of people complained about the ingalls stiffy "wearing out" or no longer dampening the engine movement. with that said youll also read in the above link the great customer service ingalls has. the ingalls stiffy is just a band aid fix for a worn out lower motor mount.
Old Aug 10, 2007 | 05:35 AM
KevinD's Avatar
www.machevo.com has them for 125.
Old Aug 10, 2007 | 08:10 AM
boostedwrx's Avatar
I still have hella engine movement even after the addition of the front mount. I need the side mounts too i think..
Old Aug 10, 2007 | 09:14 AM
prj.evo's Avatar
I have the Ingalls engine damper and it was one of the most worth-while mods I have done (for the $40 is cost me!!). Im sure a motor mount would have been just as good or better, but I got the damper off my brother for 40 bucks and its much easier to install.
The engine doesnt move a bit. Shifting is soooo much smoother and easier. Downshifting is wayy smoother. The car just feels more solid.
Old Aug 10, 2007 | 02:04 PM
dan628's Avatar
I just put the weapon-r damper on my car, it has no oil in it so it can't leak. It seems like a pretty beefy piece. That along with my Agency power lower mount makes a really good setup. Not too much vibration at idle, unless the A/C is on.
Old Aug 10, 2007 | 03:20 PM
Dr.Sound's Avatar
weapon R is ****.
i have both stiffy and AGP front motor mount. had stiffy on for 8 months before adding the motor mount. very good and QUALITY piece (unlike weapon R). helped a lot with decreasing engine movement and shifting.
AGP helped with throttle response and even more with down-shifting.
stiffy - no vibration whatsoever, but added engine noise because of the placement (close to firewall)
AGP - some vibration (esp first 2 weeks), no engine noise. almost no vibration now (4 months later).
