ses light on from high flow cat
my ses light is on and has been on sense i put my high flow cat on from RnR. i had it checked out and its from the cat. what do i need to do to get that fixed? should a high flow cat even throw a code?
You should be able to go to autozone or kragen and rent a OB2 reader or whatever its called and reset it yourself.I think its like a $175 deposit which you get back.Im runnin the Perrin HFC with spark plug defoulers and I have had 0 problems.Give some of those a shot after you get the check engine light fixed.
yeah i reset the ecu several times but it always comes back on after about i drive it about 20 or 30 miles. i will try to find one of those spark plug defoulers. thanks. if i cant find them here then i will hit you up about the one that you have.
i get it too, i also have a HFC from RNR. it's worse when it's cold out, in the summer sometimes it goes a while before throwing it. my solution was to pick up one of these for $50 http://www.amazon.com/gp/product/B00...553681-0464412
https://www.evolutionm.net/forums/sh...mechanical+fix
This will take about 5 minutes to complete. $5 and no more CEL...has worked for a couple of months with my BR HFC.
