MAF cleaner
Old Aug 11, 2007 | 10:02 AM
SpeedJunkyz's Avatar
you can get crc at wallymart
Old Aug 11, 2007 | 10:33 AM
Positron's Avatar
Do you guys reset the battery after using CRC maf cleaner? Do just leave it as is.
Old Aug 11, 2007 | 12:38 PM
Evoryder's Avatar
leave as is
Old Aug 13, 2007 | 07:18 AM
Joehunk's Avatar
Resetting the battery won't hurt anything. Well except your radio presets, lol.
Anyways I wanted to bump this thread because I had a good MAF-cleaning experience this weekend. I had my car tuned about 1500 miles ago, and it ran really fast after the tune. However, recently it had started running a little slower than usual, especially under part-throttle, and I wondered what was up. What occurred to me is that very shortly before the tune, I had installed a K&N panel filter (which is an oiled filter, and I had read recently that oiled filters can foul the MAF sensor if over-oiled, AND that K&N filters are notoriously over-oiled from the factory). So it seemed quite possible that some oil from the filter had gunked the sensor after the tune, causing it to read less air than it should. That means more air is making it into the engine than the ECU "thinks", meaning I am running lean. The tuner had cranked it up right below the knock threshold, so running lean probably meant I was setting off the sensor.
So I cleaned the guy with CRC Brake Cleaner (which I had around), reset the ECU, and whamo, my power is back just like that. I am not 100% certain resetting the ECU was necessary, but I am not sure how much the ECU "remembers" in terms of knock readings. So I plan to go with the advice of the guy that cleans the MAF at every oil change, and I will also be very conservative when re-oiling my panel filter.
Oh, BTW there was no visibly soot or anything on the MAF wire, but K&N filter oil is translucent, so I don't imagine I'd have been able to see oil deposits with the naked eye necessarily.
Old Aug 22, 2010 | 02:08 PM
raasfaas's Avatar
I was trying to find the CRC MAF Cleaner but unfortunately they don't have that one where I live, can someone confirm that this can or cannot be used...thanks
Old Aug 22, 2010 | 02:20 PM
TommiM's Avatar
bumpin a 3 year old thread. The crc maf cleaner is best to use, but you should be ok with that. some electronic cleaners leave a residue behind so just make sure whichever you go with doesnt do that.
Old Aug 22, 2010 | 02:24 PM
mifesto's Avatar
maybe straight rubbing alchohol would be good too, since its breaks down oil/dirt yet leaves no residue.
what i like to do when i clean maf is to put paper tower under it as i spray it down. this way i can gauge how dirty it was
Old Aug 22, 2010 | 03:57 PM
raasfaas's Avatar
Thanks, going to give it a shot. Well its the first that I'm cleaning it so I figure it's pretty dirty.
Old Aug 22, 2010 | 04:44 PM
88_Pathy's Avatar
Non-chlorinated brake clean is perfectly OK to use on the MAF sensor. I clean mine every oil change too.
