Does this make sense?
Old Aug 11, 2007 | 04:38 PM
4G63EVO9's Avatar
I met a guy today with an evo it had a new turbo kit on it that he said cost him 4000 dollars. When I asked him how much boost he was running he said 22psi. I am a newbie but i know with 80 dollars you can get a mbc and get the same boost on the stock turbo, so is there a point in the new turbo kit?
Old Aug 11, 2007 | 04:44 PM
596736's Avatar
His car is tuned for pump gas. If his car was on meth or race gas obviously he would be boosting more. 22psi on the stocker won't yield the same power as 22psi on a larger turbo
Old Aug 11, 2007 | 04:50 PM
1320 Engineering's Avatar
larger turbos have can compress more air than a smaller turbo. If you think of the engine as a big air pump you will realize that when a turbo is compressing more air, the engine is getting more air, making it more efficient, making more horsepower.
Old Aug 11, 2007 | 04:58 PM
Qatar_Evo's Avatar
its dosnt have to be a high boost for a bigger turbo 22psi is not like stock turbo psi
am running on my supra 0.8 bar On to4z and cams and its really fast
Old Aug 11, 2007 | 07:59 PM
impreza2darksyd's Avatar
larger turbo, more volume, more air at 22psi
Old Aug 11, 2007 | 08:03 PM
4G63EVO9's Avatar
alright i get it i always thought bigger turbo meant more boost never really thought about it in volume but it makes sense now
Old Aug 11, 2007 | 08:12 PM
whoang40's Avatar
PSI is the measurement of air at any instantaneous point in time. Volume of air is a rate per time. If you take the derivative of the cfm you'll get psi on the cfm curve if you graph it.
