Question about a floor jack.
Old Aug 13, 2007 | 07:16 PM
CrackerJackToy's Avatar
I picked up craftsman floor jack at a really good price. Its a 2.5 ton 3.5" low profile. The jack can go up to 14 inches. My question is, is 14" an ideal height for my EVO? Would a 16" REALLY make that big of a difference? Anyhow... just curious. Im going to be installing exhaust on my car soon, and coilovers and hoped this would be enough. Jack was only $35.99.
PS. I bought jack stands to go with it.
Old Aug 13, 2007 | 07:21 PM
Q@EvoPowerMods's Avatar
Before you crawl under that car put it on jack stands, any attempt to get under the car ONLY using a jack Might result in death or worse.
Old Aug 13, 2007 | 07:23 PM
evrblazin's Avatar
death or worse?
the 16" one will make a 2" difference
and yes always use jackstands
Old Aug 13, 2007 | 07:27 PM
I bought jackstands to go with it. 2.5 ton for $13.50
EVO X Owner-2-B's Avatar
Both are too short, IMO. My service jack (floor jack) goes up to 29". I also have jackstands that stand 21.5" high - at their highest setting. I call this setup a poor man's "lift" or a "lift" for a short ceiling. I couldn't be more pleased. On my creeper, I can have my knees all the way up and still not hit the bottom of my car. I have gobs of clearance.
Old Aug 13, 2007 | 07:30 PM
MTRJunior's Avatar
whats worse than death again?
and yea, I had the same jack as you...I installed my beatrush using it...it was fine for me
Old Aug 13, 2007 | 07:31 PM
k20ep3's Avatar
if it doesnt go high enough then use a 4x4 pice of wood. ive never had any problems all the years ive used that method. but jack stands are a must if your under there
DC Hydraulic is the company.
Service jack model DK13HLQ
Jack stand model 3000N-GS1
There are like three importers here in the States. It's not cheap. All told, this setup will set you back $1K-plus.
Old Aug 13, 2007 | 08:06 PM
wushu2000's Avatar
Sounds like I have the same jack, I use jackstands as well. Sometimes, depending on what I am doing I just use my rhino ramps.
Old Aug 13, 2007 | 08:18 PM
Yes there is something worse than death, like some very severe injury. Like a condition where you cant take care of yourself and others have to wipe your butt for you.
Old Aug 14, 2007 | 01:46 AM
Maxdelta's Avatar
so um yeah I am a tard I went and got a nice floor jack, forgetting I already had one so now I have 2. I got jack stands. Last weekend I helped my friend take out the transmission out of his car at the BAD *** DO IT YOUR SELF GARAGE we have on Fort Wainwright. Its 4 bucks an hour to have your car up on a Hydraulic raise. Just like at a mechanics place except they have everything you need tools, fluids, hoses computers, Alignment tools. you name it they got it EVERYTHING to build a car from the ground up. Long story short I will never ever crawl under my car to change the oil again.
Old Aug 14, 2007 | 08:30 AM
boostedorbusted's Avatar
a
its like they say 2 is better than 1 so now you have 2 jacks and not 1 good luck with them.
Old Aug 14, 2007 | 08:33 AM
rcheung's Avatar
My floorjack has a 18.5 lift and its barely high enough to put jackstands and me to go under and maneuver.
Old Aug 14, 2007 | 08:43 AM
.50 Cal Cow's Avatar
I used that 2.5 ton jack and jackstand set to do a cat back with no problems. Did the DP using a lift (good old military installation craft centers rock). But I was able do the mbc install from underneath with the same jack stand set so DP shouldn't be impossible either. Might be pita to get those spring bolts off like that though but enough Kroil and 1/2" drive breaker bar should do the trick.
Old Aug 14, 2007 | 08:44 AM
dsmythe2's Avatar
...slow death while being crushed and pinned underneath a car. It happens more often than you think.
