a/c problems...please give suggestions
Old Aug 17, 2007 | 10:52 PM
amscrazy's Avatar
I had some work done at ams awhile back (ems, cams, injectors, rail, and pump...and tuned) and everything went smoothly. Everything worked better than ever no problems anywhere.
Well about a month ago i had them install a gt30r and some head studs, and ofcourse another tune. well when i got the car back everything was working fine but the air conditioning. ???? well i had the dealership check out my a/c and they said, ofcourse, that it was my ems even though it worked fine before. well they manually tested if my a/c and the relay to the pump worked and it did, so now i dont know what is wrong with it...is the ems not sending the signal to the a/c to turn the relay and engage the pump? '
ps...by the way, the heat works fine and it blows, just not cold, and its not the refrigerant.
thanks in advance for input
Old Aug 17, 2007 | 11:02 PM
idriveanevo's Avatar
im not sure about the ems, but if worst comes to worst, you could possibly just run a wire from the control straight to the relay or pump?
Old Aug 17, 2007 | 11:07 PM
wizzo 8's Avatar
Why dont you call or go to AMS insted of the dealer. Im sure AMS could figure it out
Old Aug 22, 2007 | 08:33 PM
DBPLAYA00's Avatar
sounds like u need to check and see if the relay has power to it and if it does u need to see if it is being to trigger to come on, if no trigger to come on then find out if there is a wire connection issue or issue with ems
Old Aug 22, 2007 | 08:40 PM
Rallyman's Avatar
Don't know if this could apply to you, but some EMS (such as AEM and GEMS) have an on/off setting for A/C in the software. I suppose the setting could have been changed by accident.
Old Aug 22, 2007 | 08:55 PM
evo150's Avatar
+1
