shifter cables
Old Aug 20, 2007 | 07:09 PM
EvoJoeIX's Avatar
shifter cables
well i found out the reason my car was hard to get into gear...
it was one of the shifter cables. i brought the car in when i got off work today to take a look at everything and re-bleed my clutch. and i had one of the guys i work with play around with the cables. when he pushed the cable down a bit, the shifting got really smooth...
anyone else have this problem???
why would it be like this? i also had this problem before i put my new clutch in so its not like i damaged anything installing the new clutch
does anyone make aftermarket/ upgraded cables? or should i take the car to the dealer and have it warrantied? it only has 7200 miles on it, so i dont think it will be a problem
Old Aug 20, 2007 | 09:33 PM
cableguy5752's Avatar
It could be those BR shifter bushings you're using.
Old Aug 21, 2007 | 03:33 AM
Bonestock!'s Avatar
Doesn't the MR come with better Teflon lined shifter cables anyway? I was hoping I could use them in my GSR. My friends FQ340 is the best shifting Evo I have ever driven. I thought the Teflon cables contributed to it.
Old Aug 21, 2007 | 12:31 PM
mis4tun81's Avatar
Could be the bushings.
I have to lubricate mine once or twice a year or they seize up a bit, and make shifting hard.
Old Aug 21, 2007 | 01:38 PM
Dr.Sound's Avatar
^ +1
Old Aug 21, 2007 | 01:43 PM
Kevindanger's Avatar
the cables from a 5 speed and 6 speed are different
Old Aug 21, 2007 | 03:52 PM
EvoJoeIX's Avatar
i re-lubed the bushings when i had the trans out.....so it cant be that
ill put the rubber ones back in and see if that makes a difference
