Need Help!
Old Aug 22, 2007 | 02:32 PM
evoracer12's Avatar
Question Need Help!
Okay. I have a ix and my clutch went inches to the floor and wouldnt come back up. i checked the fluids in the engine bay and the atf fluid was low so i filled it up pumped the clutch a few times and it came right up with no problems and i started driving it again. it has been about two weeks and i havent found a leak so i assumed that it had been low to begin with and it didnt give me a problem until then. so i wake up tuesday morning and the clutch is inches to the floor and wont come back up. so i check all the fluid levels in the engine bay and everything is easily filled up to where it should be. but my clutch is still on the floor!!! i know for a fact that the clutch is still in great shape since i just had it replaced last november to my twin disc i am running now. does anyone know what could be causing this??? any suggestions would be greatly appreciated as i need to solve this as quickly as possible.
Old Aug 22, 2007 | 02:36 PM
bigric09's Avatar
atf shouldnt of did anything to your clutch.... you need to check your brake fluid. Make sure it is filled to the line. Bleed your clutch line, and that should help
Old Aug 22, 2007 | 06:53 PM
DBPLAYA00's Avatar
atf? i am confused. Automatic Transmission Fluid?
my guess is that u hav a bad clutch master cylinder, a leak, or some how got air in the clutch line.
