pinstriping
Old Aug 28, 2007 | 06:46 AM
aceinthesky2002's Avatar
pinstriping
i bought my car and it had pinstriping done to it. my question is can it be removed without repainting my car. pin stripind is thin an over the clear.
Old Aug 28, 2007 | 06:57 AM
SpeedJunkyz's Avatar
yeah pull it off, unless its painted on, then you should have the body shop do.
Old Aug 28, 2007 | 06:58 AM
E\/0IXG$R's Avatar
can you post some pics? I've never seen that before.
Old Aug 28, 2007 | 06:59 AM
Peteypab2133's Avatar
dealers always do that crap! if they did it, then it should pull right off... use some heat to get it started or some gunk lifter in a can should get it started...
how does it look, wouldn't mind seeing some pics
Old Aug 28, 2007 | 07:07 AM
NYEvoguy's Avatar
pull it off and if you have any glue left on the car go to wal mart and get this stuff call oops. Soak a rag with it and wipe it off.
Old Aug 28, 2007 | 07:10 AM
rcheung's Avatar
Old Aug 28, 2007 | 07:24 AM
El.BlueEvo9's Avatar
Use your fingers......
Old Aug 28, 2007 | 07:28 AM
evo8426's Avatar
it should come off right away with no problems. although you might now want to pull it off since your car has had it on for a while. the dealer here tried to add that to my car for $1000 just to put a silly line down the side.
becareful with the oops...it strips clear coat and first coat. I tried using that on my emblem removal and now I have dull spots.....thats ok though it in line for a repaint.
Old Aug 28, 2007 | 07:43 AM
That silly line down the side adds 50WHP!!!
Old Aug 28, 2007 | 07:58 AM
urslo4n8's Avatar
even if its painted on it can still be rubbed off with a wheel and some light compound
Old Aug 28, 2007 | 08:11 AM
donmeca2020's Avatar
i too had that damn pin strip on the side, at first i liked it then as i started to notice more evos that didnt have it on it, i was like wtf is this on my car? im not driving a regular lancer. anyways long story short after a nice wash , i called a friend over who has body shop experience he brang some liquid used for removing pin striping and what not and as we peeled it started to come right up. you still will have that shadow of it on your car, because it was on there for some time but it can only be seen in very bright light.
Old Sep 1, 2007 | 12:21 AM
i read that you can remove painted painted pin stripes with easy off oven cleaner. is this safe for our weak evo paint.
here is the link
http://us.lexusownersclub.com/forums...hp/t14709.html
Old Sep 1, 2007 | 05:11 AM
looks dangerous....
Old Sep 1, 2007 | 06:52 AM
Jakeg97's Avatar
any pics of what it looks like?
