problems @ 3500 rpm
Old Sep 6, 2007 | 05:29 AM
djulian21@juno.'s Avatar
Question problems @ 3500 rpm
I seem to have a misfire/sputtering situation occuring @ 3500 rpm, at partial throttle. I don't know if it's sparkplugs and coils, throttlebody issues, or wastegate related. Any helpful response will be greatly appreciated.
Old Sep 6, 2007 | 05:30 AM
TeStUdO's Avatar
Check your plugs first and then look for a boost leak.
Old Sep 6, 2007 | 05:36 AM
what r some of the signs/ symptoms of a wastegate malfunction?
Old Sep 6, 2007 | 05:45 AM
Dont Try To Run's Avatar
Probably a boost leak. Can you go past 3500rpm? If so, does it continue to sputter? Check your LICP or other obvious spots for a boost leak
TJ
Old Sep 10, 2007 | 03:50 PM
Neuspeed06's Avatar
Had that same problem, and it was teh filter i was using. MAF was reading all wrong.
Old Sep 10, 2007 | 03:59 PM
bluebyu36's Avatar
with a bad wastgate your car will over boost,i doubt thats your ploblem pull the plugs and check them i would have done that first before i made this thread.....maybe your mas is messed up i would try and clean it...maybe your blow off valve
